09-13-2018, 15:32 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | VFD 900 Dead After Flash with CM2 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 01D2C9AB ID_BLOCK_E : 00420030 ID_BLOCK_L : 0450C0B4F5B08E06540DD91D7F2DAA9E ID_BLOCK_L : 5935F4CA060BF5999CE2E16CA372F094 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : Vodafone ProdName : Smart_platinum7 ProdModel : VFD 900 Device : idol4s_vdf AndroidVer: 6.0.1 Manufact. : Vodafone SysPatch : MMB29M DevComTime: 7/13/2016 2:05:24 PM QLMxCPU : MSM8952 USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:17 Flashing LOG Downloaded Firmware from Support MSM8952_Vodafone_Vodafone_ANDR_v6.0.1_VFD_900_idol 4s_vdf_Smart_platinum7 Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : Vodafone Device Manufact.: Vodafone Device Model : idol4s_vdf Device CPU : MSM8952 Device IntName : Smart_platinum7 Device Version : 6.0.1 CU_SWVer : Vodafone Device Compile : 5.4.2017 7:36:16 Device ExtInfo : VFD 900 Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 01D2C9AB ID_BLOCK_E : 00420030 ID_BLOCK_L : 0450C0B4F5B08E06540DD91D7F2DAA9E ID_BLOCK_L : 5935F4CA060BF5999CE2E16CA372F094 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 53 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : adspso.bin Flashing : splash.img Flashing : sec.dat Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cmnlib.mbn Flashing : keymaster.mbn Flashing : cmnlib.mbn Flashing : keymaster.mbn Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : mdtp.img Flashing : userdata.img Flashing : gpt_backup0.bin Flash Error , Prepare data error #0 , Check battery charge! ERROR : Flashing failed! INFO : Check previous message for more info! Reconnect Power/Cable! Now Phone is detecting like this QHSUSB_BULK What to do now. |
09-14-2018, 14:25 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Disconnect battery and reconnect and try to connect phone in edl mode ( if needed via test point) and repeat flashing process. Make sure battery has sufficient power. Last flashing process was not completed. Br. Infinity Box Team. |
