VGO TEl i250 Done By CM2SPD All boxes failed but CM2 Success Phone found! [ 26 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 �Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : BY CM2 SPD 6531 Model Name : VGO TEL i250 ExtInfo Data : URDU Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD 25LQ32_URDU__BY CM2 SPD 6531-VGO TEL i250.bin Done! |
Phone found! [ 26 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 �Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Phone found! [ 26 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Check data... Can take some time User Code : 0000 Done! |
Log of MiraMonkey Failed Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Please Hold BootKey(UP and DOWN),Insert USB cable 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Scanning USB Serial port... SU2Serial Port: COM71 Connecting to Phone,Wait.. Done. Infor: SPRD3 >>Initialize boot13... |
VGO TEL - i600 Jumbo Boot Key Click Here |
plz upload file and boot key plz share the file and indicate boot key |
