Old 06-22-2016, 15:05   #1 (permalink)
Member: 1146038
Thanks Meter: 196
secuerity repair problem ....
Start  at : [22-06-2016 / 07:26:00 PM]
Operation : Repair Security [ v1.51 ]
Wait for phone...
Phone found! [ 114 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 700100563130303038500D83972D2317
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 80001
[eMMC] : FLASH_CID : 700100563130303038500D83972D2317
[eMMC] : FLASH_LEN : 0x00000001C3000000
[eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB]
DEV RID    : 0x63002BF5A9D73E1AFB160AED232187CA
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 355205806058414
IMEI [01] : 355205806058422
IMEI [02] : 911439700206756
IMEI [03] : 911439700056755
Set IMEI [00] : 911439700056755
Set IMEI [01] : 911306751708214
Set IMEI [02] : 911306751708214
Set IMEI [03] : 911306751708214
Prepare finished. Security check required!
Wait for phone...
Sync...
Repair done!
Done!
Elapsed: 00:00:32
Reconnect Power/Cable!
Finish at : [22-06-2016 / 07:26:35 PM]
i will try to repair security but all done after start phone back og imei
i will try hardreset them try but same please help
thanks advance
Old 06-22-2016, 19:32   #2 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
Write good NV then try to repair and once do full format then try
Sent from my S_plus using Tapatalk
The Following User Says Thank You to princesaddam For This Useful Post:
Old 06-22-2016, 21:06   #3 (permalink)
Member: 651892
Thanks Meter: 205
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Wait for phone...
Sync...
Repair done!
Done!
Elapsed: 00:00:32
thanks advance
Then make test "HW Test'
i think mmc in read only condition
The Following User Says Thank You to danishalnoor For This Useful Post:
Old 06-23-2016, 09:08   #4 (permalink)
Member: 1146038
Thanks Meter: 196
Chinese Miracle II  [MTK module] v 1.51
Operation : HW Test [ v1.51 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : 3746 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [KINGSTON] , 80001 , 0x1C3000000 , 7216 MiB
[eMMC] : CID : 700100563130303038500D83972D2317
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x40000000 , 1024 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1D
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:02:39
Page generated in 0.14681 seconds with 8 queries
