| No Life Poster
Member: 199814
| Virgin mobile VM621i Unlocking failed Quote:
==== log: [4/20/2011 8:06:25 PM] ====
COM6 [Serial2] selected
module v3.03
Device: Virgin-VM621i
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:5D03:A00D
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:08EA0000000000
flash: Samsung K5L2833ATA T 16Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00010000
searching rom info...
warning: wrong cs at 0x00046400, retry...
read error recovered
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is damaged, recalculation required
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: E705D3E4
rom info ver: 05
sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
project-id: MAUI.06B.W07.28.SP1.V38, 62879371
code offset: 00010000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 269
provider: 600X-2AVRGB1
customization: CJ26CW10
customization: XJ26CW10
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
rpl file not found: C:\Program Files\InfinityBox\MModule\id.E705D3E4.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_71938762].rpl
rpl file not found: C:\Program Files\InfinityBox\MModule\id.E705D3E4._JRD25_06B_P CB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_7 1938762_.rpl
rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.E705D 3E4.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_71938762].rpl
rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.E705D 3E4._JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_ 28_SP1_V38.BIN_71938762_.rpl
warning: unknown rom info structure: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_71938762
Unknown firmware detected (v.3.03, database date: ), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: support@infinity-box.biz or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
use default security area (sec info, part #1) pattern
max address is too big, should be recalculated: 08BF8000->00006F54
error: can not recalculate address range, allowed offset is too small: 00006F54
error: can't calculate security area (sec info, part #1)
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
max address is too big, should be recalculated: 08BF8000->08BF4004
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00000000000000
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Virgin-VM621i_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W0 7_28_SP1_V38__system_log_E705D3E4_71938762_2011042 0-200907.B0X.bin
Finished, time used: 2 min 23 sec
Remove/Install battery now ! |
What to do next? i tried but failed its not successful unlock |
