Old 02-01-2019, 08:02   #1 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
Unhappy VIVO 1609 y66 baseband unknown
VIVO 1609 y66 baseband unknown please help
Card found : 5raezak3 , v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.04
Load IDBase v123080 Ok!
Operation : Identify [ v2.04 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM73)
MODE : PRELOADER PORT
PORT : 73
Waiting BOOT ack ...
PRELOADER : ACK confirm FAIL!
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1844 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_SWSEC.bin
AGENT : Selected AGENT doesn't have required configuration!
Check and select CORRECT SETTINGS for your device!
Reconnect Power/Cable!
PORT : 73
BROM : Init BROM
BROM init passed!
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6755
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00002001 : DA SEND ERROR!
ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
PORT : 73
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
AGENT : DA_PL.bin
PORT : 73
BROM : Init BROM
BROM init passed!
AGENT : DA_SWSEC_CRYPTO20.bin
Operation : Repair BaseBand [ v2.04 ]
SECBackup : Enabled
PORT : 73
BROM : Init BROM
BROM init passed!
br
Old 02-01-2019, 08:44   #2 (permalink)
Member: 1677653
Thanks Meter: 2,769
Select right boot and read info 1st
Old 02-01-2019, 13:00   #3 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
select vivo v5
and connect set in brom mode with hold both volume keys in off mode
it will be boot ok
The Following 2 Users Say Thank You to kamal_singla For This Useful Post:
Old 02-02-2019, 05:40   #4 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
Originally Posted by kamal_singla View Post
select vivo v5
it will be boot ok
Card found : raezak3 , v0137
SECBackup : Enabled
PTFN : MediaTek USB Port (COM49)
MODE : BOOTROM
PORT : 49
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
MODE : Vivo : V5 | Manual : Disabled
BROM : SLA
BROM : SLA Passed!
BROM : SLA CHLNG not used
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6755
EMI : SRC : preloader_bbk6750_66_n.bin
EMI : CNT : 0007
EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ]
EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4.00 GB ]
EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ]
EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ]
EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100525831424D42 : VEN : SAMSUNG | DEV : RX1BMB : RAM : [ 3.00 GB ]
EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524531424D42 : VEN : SAMSUNG | DEV : RE1BMB : RAM : [ 3.00 GB ]
EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100524331344D42 : VEN : SAMSUNG | DEV : RC14MB : RAM : [ 4.00 GB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00000000 [ 0 B ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 150100525831424D4212C5D1C88AC35D
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX1BMB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0008 , EVOL : 0x0000
RNID : 71AE175889C4746DA69A6203FD64942
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM50)
PORT : 50
Boot done!
Backup sensetive data [ 8 ]
Backup path : Backup\MT6755__71AE175889C4746DA69A62030FD64942\
[23] Read : NVRAM
[7] Read : NVDATA
[18] Read : PROINFO
[24] Read : LK
[14] Read : PROTECT1
[15] Read : PROTECT2
Backup done!
Process Block #0
ERR : 0xC0030006
ERR : STORAGE_MISMATCH
ERR : 0x00000000|0x00000000
Error : Failed to write data! Connection ( or secured region??? ) problem!
Check cable, battery, connection and drivers!
Old 02-02-2019, 05:42   #5 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
imei repair error
Operation : Repair Security [ v2.04 ]
MODE : BOOTROM
PORT : 49
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6755
EMI : CNT : 0007
EMMC:
PORT : 50
Boot done!
Old Data :
IMEI[0] : 863714037607514
IMEI[1] : 863714037607506
IMEI[2] : 865407010000009
NVRAM check : Passed!
New Data :
IMEI[0] : 350147993200141
NVM_LID : updated!
Update NVRAM ...
ERR : 0xC0010001
ERR : ERROR
Error : Flashing failed!
Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report!
Old 02-02-2019, 06:13   #6 (permalink)
Member: 2211790
Thanks Meter: 5,118
@raezak
once try change Global Settings default to another one (from first page) and repeat operation
The Following User Says Thank You to kamal_singla For This Useful Post:
Old 02-02-2019, 06:40   #7 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
@raezak
same problem cant repair baseband and imei repair error
SECBackup : Enabled
PTFN : MediaTek USB Port (COM7)
MODE : BOOTROM
PORT : 7
Error : Failed to open port!
SECBackup : Enabled
MODE : BOOTROM
PORT : 49
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6755
EMI : CNT : 0007
EMMC:
PORT : 50
Boot done!
Backup done!
Process Block #0
ERR : 0xC0030006
SECBackup : Enabled
MODE : BOOTROM
PORT : 49
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6755
EMI : CNT : 0007
EMMC:
PORT : 50
Boot done!
Backup done!
Process Block #0
ERR : 0xC0030006
br
Old 02-02-2019, 06:58   #8 (permalink)
Member: 2211790
Thanks Meter: 5,118
change protocol to 1 and repeat
Old 02-02-2019, 07:33   #9 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
same i think not yet supported for imei repair and baseband repair
MODE : BOOTROM
PORT : 49
MODE : BOOTROM
PORT : 49
MODE : BOOTROM
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6755
EMI : CNT : 0007
EMMC:
PTFN : MediaTek DA USB VCOM (Android) (COM51)
PORT : 51
Boot done!
Patch Level : MRA58K
Display ID : MRA58K release-keys
Ver. CodeName : REL
Ver. Release : 6.0
Sec. Patch : 2018-08-05
Build Time : 1536920013
Product Model : vivo 1609
Product Brand : vivo
Product Name : 1609
Product Device : 1609
Product Board : mt6750
Product Manfct : vivo
Board Platform : mt6750
Product Info : bbk6750_66_m
Product Model : PD1612BF_EX
USERDATA : ENCRYPTED
Backup done!
Done!
Elapsed: 00:00:19
SECBackup : Enabled
MODE : BOOTROM
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6755
EMI : CNT : 0007
EMMC:
PORT : 51
Boot done!
Backup done!
Process Block #0
ERR : 0xC0010001
ERR : ERROR
br
Old 02-02-2019, 08:51   #10 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
change Global Settings and use memory tool to write nvram
Or
Erase modem partition and write NVRAM and rewrite modem file again
Page generated in 0.31008 seconds with 8 queries
