03-03-2018, 10:39 | #1 (permalink) |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | vivo 1716 MSM8953 im3i invalid problem Code: Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : vivo Device Manufact.: vivo Device Model : msm8953_64 Device CPU : MSM8953 Device IntName : PD1708F_EX Device Version : 7.1.2 CU_SWVer : vivo Device Compile : 31/08/2017 17.38.21 Device ExtInfo : vivo 1716 Code: Operation : EDL Security Operation [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 003606A4 ID_BLOCK_L : 8D4873921D80510D896309ED093488DB ID_BLOCK_L : EF542EDDD3DF16AF16AFA1E24D477AC0 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Backup Security Partitions Backup : FSG Backup : MODEMST1 Backup : MODEMST2 Backup saved to : D:\INFINITY\CM2QLM\Backup\MSM8953_[0009A0E1]_003606A4_SEC\ Done! Operation : EDL Security Operation [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 003606A4 ID_BLOCK_L : 8D4873921D80510D896309ED093488DB ID_BLOCK_L : EF542EDDD3DF16AF16AFA1E24D477AC0 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Wipe Security Partitions Erase : FSG Erase : MODEMST1 Erase : MODEMST2 Done! Code: Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 000009A0 MODHW : 0000100E BUILD : MPSS.TA.2.3.c1-00430-8953_GEN_PACK-1.108903.1.109730.1 RTIME : Sep 1 201701:01:21 BTIME : Jul 28 201702:00:00 DEVST : 8953.gen Update IMEI[1] : 865246546xxxxxx Record update FAILED! READ-ONLY! Security Wipe required! Update IMEI[2] : 865246546xxxxxx Record update FAILED! READ-ONLY! Security Wipe required! Write done! Reboot device, if it not restart! Hint : QCN write and Factory Reset is required to finish process completely! Done! Elapsed: 00.00.03 Reconnect Power/Cable! what is the problem? wbr |
