01-06-2019, 06:43 | #3 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | Card found : 7DB1869C , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.03 Load IDBase v123080 Ok! Operation : Reset Settings/Format FS [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM7) MODE : PRELOADER PORT PORT : 7 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : Vivo : V5 | Manual : Disabled BROM : SLA BROM : SLA Passed! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6755 EMI : SRC : preloader_bbk6750_66_n.bin EMI : CNT : 0007 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100525831424D42 : VEN : SAMSUNG | DEV : RX1BMB : RAM : [ 3.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524531424D42 : VEN : SAMSUNG | DEV : RE1BMB : RAM : [ 3.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100524331344D42 : VEN : SAMSUNG | DEV : RC14MB : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : Vivo : V5 | Manual : Disabled BROM : SLA BROM : SLA Passed! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6755 EMI : SRC : preloader_bbk6750_66_n.bin EMI : CNT : 0007 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100525831424D42 : VEN : SAMSUNG | DEV : RX1BMB : RAM : [ 3.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524531424D42 : VEN : SAMSUNG | DEV : RE1BMB : RAM : [ 3.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100524331344D42 : VEN : SAMSUNG | DEV : RC14MB : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM7) MODE : PRELOADER PORT PORT : 7 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM7) MODE : PRELOADER PORT PORT : 7 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM7) MODE : PRELOADER PORT PORT : 7 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM7) MODE : PRELOADER PORT PORT : 7 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
