09-12-2018, 19:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | vivo y20t firmware needed ProdName : bbk82_wet_jb5 ProdModel : vivo Y20T Device : bbk82_wet_jb5 AndroidVer: 6.1 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.MP.V1.6 Card found : S/N : A6936825 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303847393200D50CD8B0B023 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 29G80 [eMMC] : FLASH_CID : 11010030303847393200D50CD8B0B023 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xDEC55C37DB3E11390E658A4B3AC5E1FD INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : vivo ProdName : bbk82_wet_jb5 ProdModel : vivo Y20T Device : bbk82_wet_jb5 AndroidVer: 6.1 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.MP.V1.6 SECURITY : IMEI_SW [1] : 863756022066396 IMEI_SW [2] : 863756022066388 BTMAC Addr : 309BADDCF01A WiFi MAC : 309BADDCF01B MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1319_MD_TG_MP_V14_F6_P5_1_wg_ n Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
09-12-2018, 19:28 | #2 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Card found : S/N : A6936825 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303847393200D50CD8B0B023 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 29G80 [eMMC] : FLASH_CID : 11010030303847393200D50CD8B0B023 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xDEC55C37DB3E11390E658A4B3AC5E1FD INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 4096 mV [Processing] FlashMemory Read-Write test [eMMC] : [TOSHIBA] , 29G80 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 11010030303847393200D50CD8B0B023 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x40000000 , 1024 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1D [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:02:54 Reconnect Power/Cable! |
09-21-2018, 17:01 | #12 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, Right Click On Firmware Folder -> Remove Chinese Words From Rename. Post Result Please... |
The Following 2 Users Say Thank You to MyGSM World For This Useful Post: |
09-21-2018, 17:26 | #15 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | FLASH DONE BUT ONLY CHINESE LANGUAGE, PLEASE HOW TO CHANGE OR INSTALL ENGLISH LANGUAGE? |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
