09-15-2018, 01:21 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | I don't think firmware may helps with this problem, anyway let me aks users to upload firmware. Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
09-15-2018, 03:33 | #3 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2409484 Status: Offline Thanks Meter: 0 | Card found : E18C1B05 , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Write QCN (NVM) [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 00000000 MODHW : 00000FFE BUILD : RTIME : BTIME : DEVST : Diag ONLINE set Failed! Skip ... ERROR : Default SPC NOT accepted! Wrong or changed? Reconnect Power/Cable! Operation : Memory Tool Init [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 00000000 MODHW : 00000FFE BUILD : RTIME : BTIME : DEVST : Diag OFFLINE set Failed! Skip ... ERROR : Default SPC NOT accepted! Wrong or changed? Reconnect Power/Cable! |
