04-03-2019, 09:38 | #3 (permalink) |
No Life Poster Join Date: Mar 2014 Location: India
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM20) MODE : BOOTROM PORT : 20 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : Vivo : V5 | Manual : Enabled BROM : SLA BROM : SLA Passed! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6755 EMI : SRC : preloader_bbk6750_66_n.bin EMI : CNT : 0007 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100525831424D42 : VEN : SAMSUNG | DEV : RX1BMB : RAM : [ 3.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524531424D42 : VEN : SAMSUNG | DEV : RE1BMB : RAM : [ 3.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100524331344D42 : VEN : SAMSUNG | DEV : RC14MB : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
04-03-2019, 10:30 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Change EMI and repeat process. Or I have uploaded required files on support area- Vivo_Y69_DA You can download it after sometime and try again. Br. Infinity Box Team. |
