Old 03-19-2018, 05:29   #1 (permalink)
Member: 2153016
Thanks Meter: 22
Viwa light one _frp remove need help
Hi every one
i have viwa light one with frp itrayed many boot files but no luck
i searched for firmware did not find it ,,,
can any one give boot files or link for firmware
thankes to all
The Following User Says Thank You to waleedwww For This Useful Post:
Old 03-19-2018, 05:46   #2 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,240
Hello @waleedwww,need help post logs here with out log unable to help
Good Luck
The Following User Says Thank You to gracy_elec For This Useful Post:
Old 03-19-2018, 18:08   #3 (permalink)
Member: 2153016
Thanks Meter: 22
Card found : S/N : B66D1355 , v0136
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 23 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x9C
NAND Flash : NOT INSTALLED
eMMC Flash : 150100464531324D4207B74CDAE95479
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:07
Reconnect Power/Cable!
thankes for help
Old 03-19-2018, 18:48   #4 (permalink)
Member: 2739340
Thanks Meter: 70
Post log with out change da file (original infinity da file )and Try to connect with out hold volume key and post result
Old 03-19-2018, 20:17   #5 (permalink)
Member: 2153016
Thanks Meter: 22
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:07
this log with original infinity da file & with out hold volume key
Old 03-20-2018, 15:22   #6 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,240
HELLO @waleedwww, HERE IS YOUR DA FILE FOR YOUR CPU
LINK : https://drive.google.com/open?id=19f...NduWZ8pG58hLHC
GOOD LUCK
The Following 2 Users Say Thank You to gracy_elec For This Useful Post:
Old 03-21-2018, 02:25   #7 (permalink)
Member: 2153016
Thanks Meter: 22
thankes for replay but i can not download the file ,, need permission to get it , another link please ,,,,,,
thankes again for help ...
Old 03-21-2018, 05:17   #8 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,240
Hello link working recheck and post result log if problem not solved I will try
Good Luck
Old 03-21-2018, 05:57   #9 (permalink)
Member: 2153016
Thanks Meter: 22
THANKES AGAIN FOR REPLAY YOUR FILE DIDNOT WORK ,, HER IS LOG
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:06
SO I TRAID ANOTHER WAY BY SELECTING Infinix-X559__7.0__X559-H8015AB-N-170914V117 FLASH FILE IN FLASH TAPE AND YOU WELL NOT BELEAVE THIS IS THE LOG AFTER
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM21E
[eMMC] : FLASH_CID : 150100464531324D4207B74CDAE95479
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xCE3B27477609DB5038FD65EFB227942A
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : VIWA
ProdName : LIGHT_ONE
ProdModel : LIGHT ONE
Device : VIWA_LIGHT_ONE
AndroidVer: 7.0
MTKxCPU : MT6580
MTKxPRJ : alps-mp-n0.mp2-V1.30_zechin6580.we.n_P36
SECURITY :
IMEI_SW [1] : 353717090225527
IMEI_SW [2] : 353717090240526
BTMAC Addr : F2694665803C
WiFi MAC : 74BADB67FE20
Done!
Elapsed: 00:00:33
AND THIS FOR REMOVE FRP DONE
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:17
ALSO I READED THE FIRMWARE OF PHONE BUT PROGRAM CM2 SAYES THAT I CAN NOT FLASH THIS FILE TO ANOTHER PHONE ,,,
THANK YOU MR : gracy_elec FOR YOUR HELP AND TIME
Good Luck
The Following 3 Users Say Thank You to waleedwww For This Useful Post:
Old 03-21-2018, 06:21   #10 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,240
At last your problem solved so you r happy
Good Luck
Old 03-21-2018, 06:25   #11 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,240
Hello @waleedwww,I read the log is it true that start log of my da file plz re chk again
Good Luck
Old 03-28-2018, 17:51   #12 (permalink)
Member: 2747921
what link da file Viwa light one
LINK DA ?
Old 04-05-2018, 13:51   #13 (permalink)
Member: 190274
Thanks Meter: 46
Hi bro the link is asking for access request.. Please grant
Old 04-23-2018, 13:58   #14 (permalink)
Member: 340450
dude i asked for acces at artificialskill for ur file and for days u wouldn't approve i hope u get the time to do
Old 05-18-2018, 13:16   #15 (permalink)
Member: 2553802
viwa light lus frp solution i need it
i want to clear frp but using that method but failed
Page generated in 0.44175 seconds with 7 queries
