07-07-2007, 13:17 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Age: 42
Member: 426680 Status: Offline Thanks Meter: 11 | VK 530 problem (Need ur Help Infinity Team) this is my first fone which i have to flash on this box, so plz help me. What's problem it is showing and what's its possible solution. Log file is shown below. COM17 selected Device: VK530 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Skip: FFS/File system Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E flash: Amd 41DL640G/29DL640G D 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0001:227E startup mode adjusted flash: Amd 41DL640G/29DL640G D 8Mb Err: error verify try#1 to recover write error at 00000000 Err: error verify try#2 to recover write error at 00000000 Err: error verify try#3 to recover write error at 00000000 Err: error verify try#4 to recover write error at 00000000 Err: error verify try#5 to recover write error at 00000000 Err: error verify try#6 to recover write error at 00000000 data verification failed, error#00 at 00000000 try to repair... Err: error verify try#1 to recover write error at 00000000 Err: error verify try#2 to recover write error at 00000000 Err: error verify try#3 to recover write error at 00000000 Err: error verify try#4 to recover write error at 00000000 Err: error verify try#5 to recover write error at 00000000 Err: error verify try#6 to recover write error at 00000000 data verification failed, error#01 at 00000000 try to repair... Err: error verify try#1 to recover write error at 00000000 Err: error verify try#2 to recover write error at 00000000 Err: error verify try#3 to recover write error at 00000000 Err: error verify try#4 to recover write error at 00000000 Err: error verify try#5 to recover write error at 00000000 Err: error verify try#6 to recover write error at 00000000 data verification failed, error#02 at 00000000 try to repair... Err: error verify try#1 to recover write error at 00000000 Err: error verify try#2 to recover write error at 00000000 Err: error verify try#3 to recover write error at 00000000 Err: error verify try#4 to recover write error at 00000000 Err: error verify try#5 to recover write error at 00000000 Err: error verify try#6 to recover write error at 00000000 data verification failed, error#03 at 00000000 try to repair... Err: error verify try#1 to recover write error at 00000000 Err: error verify try#2 to recover write error at 00000000 Err: error verify try#3 to recover write error at 00000000 Err: error verify try#4 to recover write error at 00000000 Err: error verify try#5 to recover write error at 00000000 Err: error verify try#6 to recover write error at 00000000 data verification failed, error#04 at 00000000 try to repair... Err: error verify try#1 to recover write error at 00000000 Err: error verify try#2 to recover write error at 00000000 Err: error verify try#3 to recover write error at 00000000 Err: error verify try#4 to recover write error at 00000000 Err: error verify try#5 to recover write error at 00000000 Err: error verify try#6 to recover write error at 00000000 data verification failed, error#05 at 00000000 Writing Fail Finished, time used: 68 sec Remove/Install battery now ! I am using VK207i cable which is shown in cable selector. Plz provide me detail of problem and its solution. |
07-08-2007, 11:18 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i think there is flash IC fault. or bad soldering. can you open phone to check if there is sign of water. also you can try to heat flash ic, or better to desolder it reball and solder back |
5220 RM-411 Big problem need ur help All | G$m | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-11-2010 14:45 |
need 2 flash 2112 i need ur help on that | venuskarthick | Nokia CDMA | 11 | 12-23-2008 18:11 |
infinity need ur help | venuskarthick | Infinity-Box | 5 | 02-01-2008 01:21 |
Need Ur Help Infinity Team | ziasim | Infinity-Box | 3 | 07-04-2007 09:22 |
infinity team i need ur help.. x70 dead.. plz | KSM1 | Infinity-Box | 0 | 09-27-2005 19:41 |
