11-12-2005, 12:58 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 74
Member: 163019 Status: Offline Thanks Meter: 9 | Cannot Flash S288 It gives this error: COM50 selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Read info... FLASH: 20A0 Read info Ok Set baud... 115200 Set baud Ok Check flash... Check flash Ok Check space... Check space Ok Write... Write: Firmware Error: ERASE[FE]: 00000000 Write fail Finished Remove/Install battery now ! Time used: 15 sec Infinity,what do you think is wrong? |
11-14-2005, 07:34 | #3 (permalink) | |
Member: 163019 Status: Offline Thanks Meter: 9 | Quote:
Before,it was coming on but then go off as you try to make a call. Let me try flashing at 38400 and post result. | |
11-14-2005, 13:34 | #5 (permalink) | |
In this case it can be phone hardware problem. Open phone and check it, maybe it's water damage. | |
2330c cannot unlock, cannot flash. | hugmax | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 10-23-2009 01:11 |
KG225 cannot connect - cannot flash? | Kasper | VygisToolbox | 2 | 08-07-2007 20:39 |
Cannot flash myx-5m with sagmaster "wrong flash image" | sandokaan | ARM9 BASED M62 / M62+ | 0 | 04-03-2005 20:38 |
I Cannot Flash S300 With Opti Flash I Need Full Instraction Step BY Step | Mahmudul | Trident/AGERE Platform | 9 | 09-22-2003 22:29 |
