vk530 unknown flash chip its no power vk530 when i read eeprom or flash = after read unknown flash ship. what does it mean please COM57 selected Device: VK530 Checking data, wait... Action: Read Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... file saved: backup_eeprom-02_20080921-222313.23F.bin Err: unknown flash chip: 04AF:EA01:04AE:EA01 Err: unknown flash chip: 04AF:EA01:04AE:EA01 Err: unknown flash chip: 04AF:EA01:04AE:EA01 Err: unknown flash chip: 04AF:EA01:04AE:EA01 Finished, time used: 52 sec Remove/Install battery now ! |
i wanted to write ffs this is result; is the flash ic damaged ? COM57 selected Device: VK530 Checking data, wait... Action: Flash write Smart Write active Skip: Firmware Write: FFS/File system Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Err: unknown flash chip: 04AF:EA01:04AE:EA01 Err: unknown flash chip: 04AF:EA01:04AE:EA01 Err: unknown flash chip: 04AF:EA01:04AE:EA01 Check Space Fail Finished, time used: 19 sec Remove/Install battery now ! |
Hello, It looks like it's hardware problem, probably flash IC is damaged or bad soldered (due to even flash chip type can not be detected well). Also it may be water inside. |
thank you infinity for quic reply |
