09-20-2008, 21:35 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: tunisia
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | vk530 unknown flash chip COM57 selected Device: VK530 Checking data, wait... Action: Read Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... file saved: backup_eeprom-02_20080921-222313.23F.bin Err: unknown flash chip: 04AF:EA01:04AE:EA01 Err: unknown flash chip: 04AF:EA01:04AE:EA01 Err: unknown flash chip: 04AF:EA01:04AE:EA01 Err: unknown flash chip: 04AF:EA01:04AE:EA01 Finished, time used: 52 sec Remove/Install battery now ! |
09-20-2008, 21:45 | #2 (permalink) |
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | i wanted to write ffs this is result; is the flash ic damaged ? COM57 selected Device: VK530 Checking data, wait... Action: Flash write Smart Write active Skip: Firmware Write: FFS/File system Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Err: unknown flash chip: 04AF:EA01:04AE:EA01 Err: unknown flash chip: 04AF:EA01:04AE:EA01 Err: unknown flash chip: 04AF:EA01:04AE:EA01 Check Space Fail Finished, time used: 19 sec Remove/Install battery now ! |
09-21-2008, 09:02 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It looks like it's hardware problem, probably flash IC is damaged or bad soldered (due to even flash chip type can not be detected well). Also it may be water inside. |
