09-28-2008, 05:35 | #1 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 234955 Status: Offline Thanks Meter: 19 | vk800 problem after flashing the phone power on before i flash it. the problem is camera cannot save and tones disappear. now the phone wont power on. infinity team please help me with this problem |
09-29-2008, 08:30 | #5 (permalink) |
Member: 234955 Status: Offline Thanks Meter: 19 | tnx for the reply sir, yes i tried all from support site. here is the log: Loading file v.02... VK800_Main_VK800Z20_HZ2.91R_2005-Jul-19_Thai.4CM.bin Loaded Loading file v.02... VK800_repair_eeprom_01.4CF.bin Loaded COM5 selected Device: VK207i Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: FFS/File system Boot... Phone should be Switched OFF ! Press Power button now ! Err: boot error[02] Boot Fail Finished, time used: 3 sec Remove/Install battery now ! Current model: VK800 Loading file v.02... VK800_Main_VK800Z20_HZ2.91R_2005-Jul-19_Thai.4CM.bin Loaded Loading file v.02... VK800_repair_eeprom_01.4CF.bin Loaded Loading file v.02... VK800_Main_VK800Z20_HZ2.91R_2005-Jul-19_Thai.4CM.bin Loaded COM5 selected Device: VK800 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: FFS/File system Boot... Phone should be Switched OFF ! Press Power button now ! Err: boot error[02] Boot Fail Finished, time used: 12 sec Remove/Install battery now ! COM5 selected Device: VK800 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: FFS/File system Boot... Phone should be Switched OFF ! Press Power button now ! Err: boot error[02] Boot Fail Finished, time used: 35 sec Remove/Install battery now ! COM5 selected Device: VK800 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: FFS/File system Boot... Phone should be Switched OFF ! Press Power button now ! Err: boot error[02] Boot Fail Finished, time used: 8 sec Remove/Install battery now ! COM5 selected Device: VK800 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: FFS/File system Boot... Phone should be Switched OFF ! Press Power button now ! Err: boot error[02] Boot Fail Finished, time used: 14 sec Remove/Install battery now ! COM5 selected Device: VK800 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: FFS/File system Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E flash: Amd 41DL640G/29DL640G D 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0001:227E startup mode adjusted flash: Amd 41DL640G/29DL640G D 8Mb Flash: 0001:227E startup mode adjusted flash: Amd 41DL640G/29DL640G D 8Mb Write: FFS/File system flash: Amd 41DL640G/29DL640G D 8Mb Writing Done Finished, time used: 970 sec Remove/Install battery now ! COM5 selected COM5 selected Device must be POWERED-ON ! Connecting, wait... Err: can't read software version Err: can't read hardware version Err: Phone not powered or bad connection Err: operation not finished properly Finished Loading file v.02... VK800_repair_eeprom_01[1].4CF.bin Loaded COM5 selected Device: VK800 Checking data, wait... Action: Flash write Smart Write active Skip: Firmware Write: FFS/File system Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E flash: Amd 41DL640G/29DL640G D 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: FFS/File system Flash: 0001:227E flash: Amd 41DL640G/29DL640G D 8Mb Writing Done Finished, time used: 77 sec Remove/Install battery now ! Loading file v.02... VK800_repair_eeprom_02.4CF.bin Loaded COM5 selected Device: VK800 Checking data, wait... Action: Flash write Smart Write active Skip: Firmware Write: FFS/File system Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E flash: Amd 41DL640G/29DL640G D 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: FFS/File system Flash: 0001:227E flash: Amd 41DL640G/29DL640G D 8Mb Writing Done Finished, time used: 144 sec Remove/Install battery now ! |
09-30-2008, 08:32 | #7 (permalink) |
Member: 234955 Status: Offline Thanks Meter: 19 | cannot flash sir here is the result COM5 selected Device: Hercules 16m "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot fail Finished, time used: 9 sec Remove/Install battery now ! |
09-30-2008, 10:58 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. try to press and hold phone "Power" button long time during boot procedure 2. if phone lost tones without any reason it may be hardware problem (not sure but it may be so), it may be problems with flash chip. |
vk800 dead after flash. | hohlobaks | Infinity-Box | 6 | 03-31-2010 13:20 |
5310 problem after flash.Please help for this problem. | caremobiles | Nokia Base Band 5 ( BB-5 ) | 9 | 04-30-2009 15:39 |
d780 flashing problem...after flashing ringer problem | gsm st | SWIFT Platform | 2 | 03-22-2009 22:29 |
Problem after flash VK800, help . | mobisvit | Infinity-Box | 5 | 07-30-2007 21:17 |
Display problem after flashing t28s | mashco | Old Ericsson Phones & Sony Phones | 1 | 04-22-2001 14:59 |
