11-09-2009, 09:33 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: P A K I S T A N (RWP)
Member: 267787 Status: Offline Thanks Meter: 71 | VM621i (OT-600) Unlock Successful COM6 [VCP1] selected module v2.93 Device: Alcatel-600 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware 600X-2EVRGB1-266_XJ26CW10_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V38_2009-06-16_En_Fr_Es_It_De_VM621i_Virgin-UK.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:4203:A000 status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:08EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.EC6BC 578.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: EC6BC578 rom info protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V38, 7C39B7C4 address offset: 00020000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 266 provider: 600X-2EVRGB1 customization: CJ26CW10 customization: XJ26CW10 TCL-ID identification done ffs address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 00000000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required Special operation Done Write ... startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_EC6BC578_C4B7397C_20091109-131238.B0X.bin Area: Firmware flash: 98000300000001:08EA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..area 0x01 size is zero ................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... customization: CJ26CW10 done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... customization: CJ26CW10 done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done Finalization ... ffs formatting... flash: 98000300000001:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_EC6BC578_C4B7397C_20091109-131659.B0X.bin Finished, time used: 348 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Thanks Infinity Teem Br. Anees-ur-rehman Last edited by Anees-ur-rehman; 11-09-2009 at 09:39. |
The Following 5 Users Say Thank You to Anees-ur-rehman For This Useful Post: |
11-09-2009, 09:48 | #2 (permalink) | |
Thanks a lot for test report ! Due to it's new supported model, please, test this phone carefully and let us know about results. | |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
11-09-2009, 10:06 | #3 (permalink) |
Member: 267787 Status: Offline Thanks Meter: 71 | Dear Phone working fine Signal , LCD Contrast , Dail Call n received calls All ok Working Fine Br. Anees-ur-rehman |
The Following 2 Users Say Thank You to Anees-ur-rehman For This Useful Post: |
11-09-2009, 18:44 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2007 Location: Inside of my computer
Member: 490708 Status: Offline Sonork: 100.1587135 Thanks Meter: 569 | great work....................always free |
The Following User Says Thank You to mohsin10 For This Useful Post: |
11-16-2009, 22:32 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is direct unlock solution for Alcatel models. It's beta solution, need to test it and see what will be the results. Please, try to unlock phone with this new software: http://www.infinity-box.com/download...dule_v2.94.rar It is no need to flash phone, just use "SP-Unlock" button from software "Service" page. Waiting for your results. |
05-21-2010, 13:04 | #11 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 356169 Status: Offline Thanks Meter: 34 | Phone working fine Signal , LCD Contrast , Dail Call n received calls All ok Working Fine it working for me......... |
The Following User Says Thank You to labsmaster For This Useful Post: |
07-01-2010, 15:25 | #12 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | ALCATEL OT-600 VM621i 600x UNLOCK DONE COM9 [VCP0] selected module v3.44 Device: Alcatel-600X, 600A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001B03:A00E status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:08EA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.D526B 662.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_A9B8E7D8].rpl rom info detection finished ==================== New firmware detected (v.3.44, database date: 14.06.2010): JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== TCL-ID detection... TCL-ID detection done device-id: D526B662 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, D8E7B8A9 code offset: 00020000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 269 provider: 600X-2AVRGB1 customization: CJ26CW10 customization: XJ26CW10 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->00006F54 error: can not recalculate address range, allowed offset is too small: 00006F54 error: can't calculate security area (sec info, hash) security area (sec info, cust) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600X,600A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B _W07_28_SP1_V38__system_log_D526B662_A9B8E7D8_2010 0701-192014.B0X.bin Finished, time used: 4 min 37 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to m_tahir1 For This Useful Post: |
alcatel Ot 600 Unlock Problem [Answered] | sanjoychy | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 4 | 02-06-2017 13:35 |
Alcatel OT-600 Unlock Done With Rx,Tx | ..::Waqar::.. | Infinity-Box | 5 | 10-12-2010 17:07 |
ot-600 unlock | nifboy | Infinity-Box | 3 | 11-16-2009 22:53 |
alcatel OT-600 unlock by imei:( | mashraf32 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 10-28-2009 14:41 |
Ot-600 Unlock Successfull | Allunlockingsource | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 3 | 09-06-2009 13:13 |
