02-16-2010, 13:27 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Vodafone 125 dead after flash I flash it with two flash files but same. plz help Infinity team. |
02-16-2010, 15:15 | #2 (permalink) |
No Life Poster Join Date: Sep 2007 Location: india up.
Member: 599228 Status: Offline Thanks Meter: 112 | felash this file problam solv 100% ok ZTE-125_main_ED-DE-P108A1V1.0.0B02_Aug-13-2007__VDF-P108A1B07-De-DE03_g3dBV2.0.B1M ZTE-125_LP_ED-DE-P108A1V1.0.0B02_Aug-13-2007__VDF-P108A1B07-De-DE03_g3dBV2.0.B1P |
The Following 2 Users Say Thank You to jamaletw For This Useful Post: |
02-17-2010, 08:29 | #3 (permalink) |
Member: 1086393 Status: Offline Thanks Meter: 771 | what this error means-- Code: COM8 [VCP0] selected module v1.73 Device: ZTE-125 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: -DE-P108A1V1.0.0B02 VDF-P108A1B07-De-DE03 g3dBV2.0 16 59 13 04.1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20100217-115439.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20100217-115440.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20100217-115441.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware repair write error [00446800:0800]... error: write failed[00400000] Write Failed Finished, time used: 53 sec Remove/Install battery now ! |
02-17-2010, 09:03 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | 1. charge battery with external power supply 2. flash phone again if you will see the same error again and again this means that it's a hardware problem (f.e. damaged or bad soldered flash chip). |
02-17-2010, 10:53 | #5 (permalink) |
Member: 1086393 Status: Offline Thanks Meter: 771 | i got this error--plz help Code: COM8 [VCP1] selected module v1.73 Device: ZTE-125 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: FF00:FFFF Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 0000000A reading eeprom-security... reading eeprom-complete... backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware error: set erase range error: erase failed: 00400000 Write Failed Finished, time used: 1 min 50 sec Remove/Install battery now ! |
02-17-2010, 20:44 | #7 (permalink) | |
In most cases it's a hardware problem (damaged or bad soldered flash chip). | |
08-28-2010, 16:56 | #8 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Raiganj Age: 37
Member: 1175794 Status: Offline Thanks Meter: 186 | here is it vodafone 125 unlocked |
Vodafone 541 dead after flash | Farshedjon | Infinity-Box | 4 | 06-14-2010 13:14 |
Zte 125 dead after flash | luyanda | Infinity-Box | 2 | 01-09-2009 15:31 |
zte vodafone 225 dead after flash | ahmedasmet | Infinity-Box | 3 | 10-30-2008 15:14 |
vodafone 125 blocked after flash | melgsm | Infinity-Box | 2 | 10-15-2008 23:12 |
Vodafone 226FM dead after flash | andrew_tm | FuriousGold | 3 | 09-11-2008 07:11 |
