Old 10-19-2008, 06:25   #1 (permalink)
Member: 573404
Thanks Meter: 5
vodafone 125 & LG KP100 success unlock by infinity
vodafone 125 & LG KP100 unlock by infinity.....
heres the logs of vodafone 125
COM3 [VCP0] selected
Device: ZTE-125
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20081019-115047.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20081019-115053.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20081019-115055.B1E.bin
reading additional data...
done
backup critical area Done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, Remove/Install battery now !
Time used: 145 sec
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
LG KP100 hers los.....
==== log: [10/19/2008 11:29:31 AM] ====
Device: LG-KP100
Action: unlock
read unlock codes
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
sw version: ULC2GL O2 KP100 04 FL 49 V10a 262-07 FEB-12-2008 +2 ^
Check hardware Done
Check parameters...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081019-112949.B1E.bin
loading data...
data loaded
imei: 35996101893917300
reading [eeprom-sec_35996101893917300]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101893917300_20081019-112953.B1E.bin
reading [eeprom-complete_35996101893917300]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101893917300_20081019-112955.B1E.bin
Check memory...
loading data...
data loaded
code: 17030047
Time used: 22 sec
pinout found at the infinity
The Following 2 Users Say Thank You to raffy_84 For This Useful Post:
Old 10-19-2008, 10:05   #2 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,159
Good test report.keep going on and on. Infinity is always the best..
Old 10-19-2008, 10:14   #3 (permalink)
howell's Avatar
Member: 697643
Thanks Meter: 68
yeah!! INFINITY is a money maker!!! he he he
Old 10-19-2008, 14:37   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
@raffy_84
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 10-20-2008, 14:35   #5 (permalink)
Member: 293499
Thanks Meter: 39
FG Failed, Infinity Done it
KP100 read code
COM9 [VCP1] selected
Device: LG-KP100
Action: unlock
read unlock codes
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
sw version: ULC2GL 2008-03-06 1.0 TMO_UK KP100 01 FL 44 V10a 234-30 MAR-0
Check hardware Done
Check parameters...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081020-133313.B1E.bin
loading data...
data loaded
imei: 35588202137764500
reading [eeprom-sec_35588202137764500]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35588202137764500_20081020-133318.B1E.bin
reading [eeprom-complete_35588202137764500]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202137764500_20081020-133327.B1E.bin
Check memory...
loading data...
data loaded
code: 61655928
Time used: 33 sec
The Following User Says Thank You to londonmoney For This Useful Post:
Old 10-20-2008, 16:17   #6 (permalink)
Member: 130995
LG KP100 Successfully Unlocked zeerik Infinity-Box 11 06-18-2012 09:24
LG GB102 Successfully Unlocked with infinity unlocklogs.com Infinity-Box 69 06-09-2011 02:10
LG B2050 successfully formatted by infinity somratjisan Infinity-Box 2 02-23-2011 13:17
.:MyPhone B21 successfully unlock by Infinity using Sir YellowBoss Trick:. andy-r Infinity-Box 3 03-06-2010 22:53
t280i success unlock by infinity jakoy Infinity-Box 1 08-12-2008 06:50
Page generated in 0.32028 seconds with 8 queries
