Vodafone 125 still locked I have got one VODAFONE 125 , locked, I have use infinity it show ok but still SIM LOCKED. here is LOG. COM6 [VCP0] selected Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20080923-112248.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20080923-112252.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20080923-112259.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 41 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
why u telling me about VODAFONE CLIP, I know i can do it with FURIOUS GOLD. But i need a solution with INFINITY (THEN BEST UNLOCKING DEVICE) |
Hello, 125 with blocked unlock counter can not be unlocked with Infinity-Box yet. |
yes, FG can do this problem:D |
your phone Blocked , use sagdd then cost 1 credits , your phone unblocked & unlocked ok ,, Br, Noman Gujjar |
How will you know if the unlock counter is block? after i Flash the phone and unlock I powered on the phone put a SIM and nothing pop up like enter code?how do we enter code 12345678? TIA |
Hello, If you can not enter unlock code this meas that unlock counter is blocked. |
Try this bro Quote:
insert any simcard if is simlock then forget it,you gat to use fg to unlock it,but network lockcode then you can enter 12345678 and boom there is unlock,,,:p |
Only SMTI can unlock and reset Vodafone 125...Tried and tested... |
br :) |
Hello, Please, try to use this new Pana01 v1.56 software: http://www.infinity-box.com/download...na01_v1.56.rar We are waiting for your results. |
Thanx for good work..It works for my ZTE 125(blocked) |
no more sim locked........no more credits |
