01-18-2008, 09:32 | #1 (permalink) |
Banned Join Date: Jan 2007 Location: India Age: 34
Member: 432364 Status: Offline Thanks Meter: 270 | Vodafone 125 unlock Infinity team.... I have one vodafone ztc 125 This phone is coming with vodafone sim in india....When i insert any other sim card its asking "Enter phone code" I tried reset to default by selecting ztc-225....But i m not able to unlock this....This phone cable cannactor is same like ztc-225....I modified cable n phone is connecting with software.... Here is log of reset to default , read eeprom n read flash COM3 [VCP0] selected Device: ZTE-225 Checking data, wait... Action: reset Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20080118-132834.B1E.bin loading data... wrong database file: z225_eep65535.cfg error: can't load database[11] Reading [eeprom-sec]... file saved: backup_eeprom-sec_20080118-132834.B1E.bin Reading [eeprom-dyn]... file saved: backup_eeprom-dyn_20080118-132836.B1E.bin backup critical area Done Check memory... Check memory Done Write... error: set erase range error: set erase range Write Failed Finished, Remove/Install battery now ! Time used: 22 sec COM3 [VCP0] selected Device: ZTE-225 Checking data, wait... Action: read eeprom Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20080118-133742.B1E.bin loading data... wrong database file: z225_eep65535.cfg error: can't load database[11] Reading [eeprom-sec]... file saved: backup_eeprom-sec_20080118-133742.B1E.bin Reading [eeprom-dyn]... file saved: backup_eeprom-dyn_20080118-133744.B1E.bin backup critical area Done Check memory... Reading [eeprom-complete]... file saved: backup_eeprom-complete_20080118-133750.B1E.bin Completed Finished, Remove/Install battery now ! Time used: 21 sec COM3 [VCP0] selected Device: ZTE-225 Checking data, wait... Action: read flash Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20080118-133815.B1E.bin loading data... wrong database file: z225_eep65535.cfg error: can't load database[11] Reading [eeprom-sec]... file saved: backup_eeprom-sec_20080118-133816.B1E.bin Reading [eeprom-dyn]... file saved: backup_eeprom-dyn_20080118-133818.B1E.bin backup critical area Done Check memory... Reading [flash]... file saved: backup_flash_20080118-134506.B1X.bin Completed Finished, Remove/Install battery now ! Time used: 425 sec I uploaded all files.... http://rapidshare.com/files/84702678...-125_files.rar Plz add this model in infinity software....Thx.... Best regards, Sunil. |
01-18-2008, 12:29 | #3 (permalink) |
Member: 432364 Status: Offline Thanks Meter: 270 | I tried by selecting zte-a35....Now phone is unlocked.....Here is log..... COM3 [VCP0] selected Device: ZTE-A35 Checking data, wait... Action: reset Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20080118-165639.B1E.bin loading data... wrong database file: za35_eep65535.cfg error: can't load database[11] Reading [eeprom-sec]... file saved: backup_eeprom-sec_20080118-165640.B1E.bin Reading [eeprom-dyn]... file saved: backup_eeprom-dyn_20080118-165641.B1E.bin backup critical area Done Check memory... Check memory Done Write... Write Done Finished, Remove/Install battery now ! Time used: 25 sec B.r. Sunil. |
The Following User Says Thank You to ..::Sunil::.. For This Useful Post: |
01-18-2008, 13:59 | #4 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
are you sure that your phone is unlocked!! you have selected reset action that gaves more pocibilities to enter code but can't unlock the mobile acton : reset == reset simlock counter but it's not a unlock act | |
01-18-2008, 14:52 | #5 (permalink) | |
Member: 432364 Status: Offline Thanks Meter: 270 | Quote:
B.r. Sunil. | |
01-19-2008, 07:32 | #7 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: Dubai
Member: 45561 Status: Offline Thanks Meter: 59 | thanks Quote:
ZTE 125 / Vodafone 125 Unlock problem | sirbigman | FuriousGold | 4 | 02-27-2010 14:28 |
Vodafon 125 unlock code | ahmetif | Phone Unlocking Codes & Maps | 5 | 11-14-2009 01:13 |
Vodafone 125 Unlocked 100%100 With Fgb | .::AssAnovic.:: | FuriousGold | 2 | 02-24-2008 06:23 |
Tested FG team vodafone 125 unlock free | F@RUK S | FuriousGold | 6 | 02-23-2008 19:04 |
Vodafone 125 Unlock Code Needed | neophyte1978 | Phone Unlocking Codes & Maps | 3 | 02-22-2008 18:49 |
