07-29-2012, 10:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | vodafone 135 COM24 [VCP0] selected module v4.36 Device: Vodafone-135 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:4D0F:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25032501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.4.36, database date: 13.01.2011): FOXLINK23D_08A_PCB01_GSM_MT6223_S00.BM32A1_V2_14_M 00_02_14.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: FOXLINK23D_08A_PCB01_GSM_MT6223_S00.BM32A1_V2_14_M 00_02_14.BIN project-id: BM32A1.V2.14.M00.02.14, 00000000 code offset: 00000000 ffs offset/size [01]: 00380000/00080000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00380000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: BM32V2MP_NP89E528UHG65K002G4PQ area1 is invalid area2 is invalid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Vodafone-135_FOXLINK23D_08A_PCB01_GSM_MT6223_S00.BM32A1_V2_ 14_M00_02_14__ffs... file saved: C:\InfinityBox\MModule\Vodafone-135_FOXLINK23D_08A_PCB01_GSM_MT6223_S00.BM32A1_V2_ 14_M00_02_14__ffs_20120729-115607.B0E.bin flash: EC257E25032501:2BEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: EC257E25032501:2BEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Vodafone-135_FOXLINK23D_08A_PCB01_GSM_MT6223_S00.BM32A1_V2_ 14_M00_02_14__system_log__00000000_20120729-115622.B0X.bin Finished, time used: 2 min 7 sec Remove/Install battery now ! what is the problem please still locked |
07-29-2012, 10:07 | #2 (permalink) |
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | vodafone135 i have tried even this chinese miracle COM24 [VCP0] selected module v3.26 Action: read unlock codes unlock method: read codes Model: Autodetect 6228-6253 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:4D0F:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: BM32A1.V2.14.M00.02.14 Version: FOXLINK23D_08A_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35412403358737 connection Ok detecting structure #1... 0 1warning: wrong packet cs 2 3 4 7 8 9 13 14 15 17 18 19 20 21 22 25 26 27 31 32 33 35error: detection failed (24 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 18 sec Remove/Install battery now ! but still not locked |
A35 Vodafone ver.13F/E/H | bre786 | x1x to x45/x50 | 3 | 11-14-2001 18:52 |
FLASH FILE FOR ALCATEL 300 V.135 | Pandemonio100 | Alcatel & TCL Old Models | 5 | 04-13-2001 11:25 |
BE4 135 | vampire | Alcatel & TCL Old Models | 0 | 02-27-2001 19:09 |
I need urgently flash for 301 v. 135! | Bootstrap | Alcatel & TCL Old Models | 2 | 02-24-2001 19:10 |
Be4 135 | ssbul | Alcatel & TCL Old Models | 0 | 01-30-2001 14:39 |
