Old 11-08-2008, 05:26   #1 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
vodafone 225 cant unlock
im trying to unlcok vodafon 225 with infinity
every thing goes ok and it says that i should put 12345678 code to unlock the set
but
when i power on the phone and i try to put this code the phone stays the same
The Following User Says Thank You to gsm2start For This Useful Post:
Old 11-08-2008, 05:39   #2 (permalink)
Member: 366714
but
Yes! Same problem for me also. Infinity says that is counter block.
No solution yet.......
but in the supporting models they add Vodafone 225.
I'm also still waiting...and waiting....and waiting!
Old 11-08-2008, 05:46   #3 (permalink)
JHUN PANABO's Avatar
Member: 785769
just put the code
untill,the remaining min. left
are gone....it means your phone
is unlock...
Old 11-08-2008, 07:24   #4 (permalink)
Cellcraft India's Avatar
Member: 287529
Flash the phone, then try unlocking.Everything will be ok.Tested many times.
Old 11-08-2008, 07:27   #5 (permalink)
Member: 348860
oh realy can you share your files coz i have 2pcs here
Old 11-08-2008, 08:04   #6 (permalink)
sebY7676's Avatar
Member: 637351
And i need some solution...i wait something from long time
Old 11-09-2008, 07:54   #7 (permalink)
Member: 287529
What solution ??? What you mean ?
Old 11-09-2008, 09:36   #8 (permalink)
Member: 366714
I don't know how you are going to given solution.....
Still Infinity says it can't do.
Old 11-10-2008, 06:08   #9 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
did you test it your self ?????????????????
coz i reflashed it will alot of flash files
on diff sets
and when i unlock it says ok but in fact its not unlocked
Old 11-10-2008, 06:28   #10 (permalink)
rose4u86's Avatar
Member: 500858
Sonork: 1589054
then ur phone is blocked. u can unlock this phone with sagdd via one log.
Old 11-10-2008, 06:37   #11 (permalink)
Member: 287529
Yes that's correct,counter blocked phones not possible.
Old 11-21-2008, 13:01   #12 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
Please, try to use this new Pana01 v1.56 software:
http://www.infinity-box.com/download...na01_v1.56.rar
We are waiting for your results.
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 11-21-2008, 14:31   #13 (permalink)
Member: 767451
Originally Posted by InfinitySupport View Post
Hello,
COM4 [VCP1] selected
module v1.56
Device: ZTE-225, Vodafone-225
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:22A0
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-sta...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-sta_20081121-173021.B1E.bin
loading data...
data loaded
reading eeprom-sec...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-sec_20081121-173023.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-complete_20081121-173026.B1E.bin
reading additional data...
done
backup critical area Done
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 23 sec
Remove/Install battery now !thanx in finity team this is update we was waiting for zte goooooooooooooooooooooooooooooooood job nice sir%10000000000000000000000000000000000000
The Following User Says Thank You to fidmdoe For This Useful Post:
Old 11-21-2008, 14:36   #14 (permalink)
Member: 767451
module v1.56
Device: ZTE-125
Action: reset
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20081121-174359.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20081121-174401.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20081121-174404.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 18 sec
Remove/Install battery now ! and 125 too unloked thanx too
Old 11-21-2008, 14:37   #15 (permalink)
Member: 767451
it was two lock sfone code and counter blocked now unloked thanxxxxxxxxxxxxx infinity team
Vodafone 225 no unlock. v11 FuriouS TeaM Products 3 06-03-2008 09:36
Vodafone 225 network unlocking code ezooper Phone Unlocking Codes & Maps 0 05-31-2008 07:49
vodafone 225 after unlock dead ruvanw1979 FuriouS TeaM Products 2 05-27-2008 08:16
Vodafone 225 cant unlock ..::GsmHelp::.. FuriouS TeaM Products 3 05-17-2008 23:20
Hi Vodafone 225 Not Unlock tornado2008 Infinity-Box 2 04-15-2008 15:10
Page generated in 0.56053 seconds with 11 queries
