10-14-2008, 11:36 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: india Age: 47
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | vodafone 225 dead when flash Device: ZTE-225, Vodafone-225 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... slowest Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware repair write error [00410000:0800]... error: write failed[00400000] Write Failed Finished, Remove/Install battery now ! Time used: 29 sec |
10-26-2008, 17:16 | #3 (permalink) |
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | yas i tried with full charge battery or direct powar but same COM3 [VCP0] selected Device: ZTE-225, Vodafone-225 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Firmware Writing: Firmware repair write error [00401000:0800]... error: write failed[00400000] Write Failed Finished, Remove/Install battery now ! Time used: 37 sec |
10-26-2008, 20:40 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It was my fault, I should never ask two questions in one message. So, let me ask only one question per message now: What was with phone before flash ? |
10-27-2008, 05:09 | #5 (permalink) |
Freak Poster Join Date: Jul 2008 Location: india Age: 40
Member: 812373 Status: Offline Sonork: [email protected] Thanks Meter: 47 | restore backup...........................my be done...... |
06-23-2009, 03:47 | #12 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | Yes select bsnl-200 and flash your phone 100000000000000000% flash done i tested 50 sets all complet flash without any problem infinity is the best |
06-01-2010, 14:15 | #13 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | done sucessfully by this method COM3 [VCP0] selected module v1.60 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100601-184137.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100601-184138.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100601-184145.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Write Done Finished, time used: 226 sec Remove/Install battery now ! |
vodafone 225 dead after flash... | jagdish1747 | Infinity-Box | 8 | 02-12-2010 18:27 |
Vodafone 225 dead la unlock.... | v11 | FuriousGold | 5 | 02-03-2010 18:20 |
vodafone 225 dead by flash | Pragyan_Gehlot | Infinity-Box | 11 | 09-26-2009 09:02 |
Zte 225 dead duriang flash | rajivmobil | Infinity-Box | 2 | 05-28-2009 04:29 |
zte vodafone 225 dead after flash | ahmedasmet | Infinity-Box | 3 | 10-30-2008 15:14 |
