04-09-2009, 12:26 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 399228 Status: Offline Thanks Meter: 66 | vodafone 225 flashing error COM6 [VCP0] selected module v1.60 Device: ZTE-225 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... sw version: -TU-P108A2V1.0.0B03 VDF-P108A2B06-Tu-TU02 g3dBV2.0 7 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-static_20090409-164346.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-security_20090409-164347.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-complete_20090409-164354.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack error: erase failed: 00650000 Write Failed Finished, time used: 231 sec Remove/Install battery now I flash the phone with this files: -ZTE-225_Main_VDF-P108A2B06-Tu-TU02_g3dBV2.0_Jun-5-2007.B1M.bin -ZTE-225_LP_VDF-P108A2B06-Tu-TU02_g3dBV2.0_Jun-5-2007_Tr.B1P.bin -ZTE-225_repair_ffs_01.B1F.bin -ZTE-225_repair_eeprom_complete_01.B1E.bin Please help . |
04-09-2009, 18:40 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can try to use ZTE-225 file that contain firmware+lp in one file, f.e. this file: ZTE-225_main_lp_VDF-P108A2B07-Pt-PT04_Sep-22-2008.B1M.bin |
04-10-2009, 14:51 | #5 (permalink) |
Member: 399228 Status: Offline Thanks Meter: 66 | Problem solved. When i flash with only firmware above (ZTE-225_main_lp_VDF-P108A2B07-Pt-PT04_Sep-22-2008.B1M.bin ), handset was still dead. Then i flash it with all three files including ffs , eeprom on ticking unlock during flash & reset setting handset is alive & unlocked. Files i use are as below: TE-225_main_lp_VDF-P108A2B07-Pt-PT04_Sep-22-2008.B1M.bin ZTE-225_repair_ffs_01.B1F.bin -ZTE-225_repair_eeprom_complete_01.B1E.bin Here is a log: COM6 [VCP0] selected module v1.60 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20090410-190102.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20090410-190103.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20090410-190110.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Erasing: FFS-2/File system Writing: FFS-2/File system Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 449 sec Remove/Install battery now ! Thanks much infinity support. |
The Following User Says Thank You to amit_varietymob For This Useful Post: |
Vodafone 225 flash error | Riteshgpt60 | Infinity-Box | 5 | 01-16-2010 02:17 |
Vodafone 225 unlock error with SAGDD | XHouser | SAGEM JTAG UNLOCKER | 8 | 06-07-2008 09:42 |
Vodafone 225 Unlock Error | Nasmi | FuriousGold | 11 | 02-25-2008 19:17 |
Vodafone 225 reset error | masterross | MT-BOX | 1 | 02-03-2008 12:07 |
vodafone 225 unlock error?????????????? | mrphuc | MT-BOX | 18 | 10-19-2007 14:09 |
