12-13-2008, 12:23 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Prizren
Member: 841080 Status: Offline Thanks Meter: 177 | <<<<...Vodafone 225 unlock Done...>>>>> module v1.57 Device: ZTE-225, Vodafone-225 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: -DE-P108A2V1.0.0B03 12 27 46 VDF-P108A2B07-De-DE03 g3dBV2.0 04.1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-static_20081213-115811.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-security_20081213-115812.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-complete_20081213-115818.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_lock-area_20081213-115825.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 39 sec Remove/Install battery now ! |
The Following User Says Thank You to svchost For This Useful Post: |
12-13-2008, 16:05 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
12-14-2008, 10:24 | #3 (permalink) |
Insane Poster Join Date: Mar 2003 Age: 50
Member: 25320 Status: Offline Thanks Meter: 11 | yes vodaphone 225 unlocked i tested on 10 ps but if phone is blocked (wrog code entered many times) and can not enter codes what is the solution this problen have also on 226 and other vodaphone models ? |
12-14-2008, 10:36 | #5 (permalink) |
Member: 25320 Status: Offline Thanks Meter: 11 | on 2 ps 225 when i press unlock - the procedure is 100% complete and phone must be unlocked but is still locked i tried to flash phone bus same result what exactly is procedure for blocked 225 ? and i think it is some patch metod for unlock because on every phone code is same 123456789 whit mt-box each phone have diferend code for unlock |
12-14-2008, 11:19 | #6 (permalink) | |
Easy solution: go to Infinity-Box support area and download latest Pana01 update. Then use latest update and unlock phone directly (even if unlock counter is blocked), no need to enter any code. I suggest you to visit support area more often due to Infinity-Box makes updates extremely fast so you must go to support area and check for updates at least 2 times per week. Also for future I suggest you to make "search" or at least read this thread from time to time: http://forum.gsmhosting.com/vbb/show...207203&page=35 | |
!!!!!!<<<< lg u900 unlock done >>>>!!!!!! | svchost | Z3X-Team Products | 3 | 08-18-2010 00:20 |
!!!!<<<< N82-1 Unlock Done >>>>!!!! | .::LUQMAN::. | Universalbox | 0 | 05-06-2009 13:24 |
Vodafone 225 unlock done | srkhan | Infinity-Box | 3 | 01-24-2009 18:56 |
Vodafone-225 unlock done...... | svchost | Infinity-Box | 2 | 12-30-2008 17:54 |
vodafone zte 225 unlock done | vodafone_banha | FuriousGold | 7 | 02-24-2008 21:49 |
