12-29-2008, 10:01 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Age: 59
Member: 185776 Status: Offline Thanks Meter: 73 | vodafone 226fm after unlock dead ==== log: [12/29/2008 1:57:49 PM] ==== COM3 [VCP0] selected module v1.58 Device: Vodafone-226FM Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20081229-135806.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20081229-135807.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20081229-135808.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20081229-135809.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area error: erase failed: 00480000 Write Failed Finished, time used: 27 sec Remove/Install battery now ! |
12-29-2008, 11:03 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Write this file into phone: \flashfiles\Sagem\repair\Vodafone-V226FM_EDI_IF_040108_1352_lock_area_original.B1E.b in and then repeat unlock process again. |
12-30-2008, 08:37 | #6 (permalink) |
Member: 185776 Status: Offline Thanks Meter: 73 | ==== log: [12/30/2008 12:47:24 PM] ==== COM3 [VCP0] selected module v1.58 Device: Vodafone-226FM Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20081230-124740.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20081230-124741.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20081230-124742.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 23 sec Remove/Install battery now ! ==== log: [12/30/2008 12:55:22 PM] ==== COM3 [VCP0] selected module v1.58 Device: Vodafone-226FM Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20081230-125537.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20081230-125537.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20081230-125538.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20081230-125540.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 20 sec Remove/Install battery now ! Thank u for ur good support,Now set is ON and Unlocked successfully,Thanks to my money making machine. |
The Following User Says Thank You to cellbhai For This Useful Post: |
unlock vodafone 541 after unlock we need calibration tuoch sceer | lilong_lee | Infinity-Box | 0 | 02-23-2010 08:04 |
sagem vodafone 226 after unlock dead | amin1999 | Infinity-Box | 13 | 01-07-2010 23:33 |
Vodafone-226FM not unlocked | bimes | Infinity-Box | 5 | 01-18-2009 15:33 |
vodafone 225 after unlock dead | ruvanw1979 | FuriousGold | 2 | 05-27-2008 08:16 |
V980 Vodafone Error After Unlock | 2lits | Ultima Box Light | 13 | 09-11-2007 08:44 |
