12-31-2007, 18:34 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: United States Age: 50
Member: 259133 Status: Offline Thanks Meter: 22 | Need To Unlock Lg Mg180 i have an lg mg180 to unlock i connect the phone to infinity and i can change imei, i can check phone info, everything ok, i selected lg mg161, and i hit unlock, and it does everything, and at the end it says unlocked, but when i insert a sim card, the phone says locked, i tried the two different methods on infinity, but no luck any suggestion please? here is the log COM4 [VCP0] selected Device: LG MG161 Checking data, wait... Action: unlock direct unlock method #1 Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL ** Central AM II ** MG160aP16FL AM_MD2 V09b XXX-XX Mar 28 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20071231-133107.B1E.bin loading data... data loaded imei: 01117200513393300 Reading [eeprom-sec_01117200513393300]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_01117200513393300_20071231-133112.B1E.bin backup critical area Done Check memory... loading data... data loaded loading data... data loaded loading data... data loaded loading data... data loaded code: 54260090 code: 0000000000000000 error: not locked or unknown eeprom Check memory Failed Finished, Remove/Install battery now ! Time used: 24 sec now i see it says not locked or unknown eeprom |
01-01-2008, 10:44 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, read flash from this phone and send to [email protected] How to enter unlock code: Infinity-Box How to enter unlock code LG-MG160 MG161 KG270 KG271 KG275 KG276 KG278 KG288 KG370 KG375 Phone is locked but does not as to enter code: 1. insert any wrong Sim-Card in phone 2. you will see on LCD: "insert correct sim" 3. type unlocking code and press Call "Green" button 4. wait for few seconds - phone will restart and unlocked |
01-02-2008, 19:45 | #3 (permalink) | |
Member: 259133 Status: Offline Thanks Meter: 22 | Quote:
what is says is " telefono bloqueado" (sim lock), what can i do? | |
01-02-2008, 23:23 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @lacasapc Did you tried to use other "unlock methods" ? What is the results ? Did you tried to use the next instruction ? Phone is locked but does not as to enter code: 1. insert any wrong Sim-Card in phone 2. you will see on LCD: "insert correct sim" 3. type unlocking code and press Call "Green" button 4. wait for few seconds - phone will restart and unlocked |
04-01-2008, 02:40 | #7 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 47
Member: 86579 Status: Offline Thanks Meter: 70 | same problem here i used the red code metthod for an mg160a Movistar. It read a code but i cant introduce it to the phone, none of the codes worked, it says SIM LOCK even with its original provider. i tried direct unlock method 1 and 2, both say unlock ok but the phone i still locked. i flashed it with all the different eeprom repair for this model on the support section and none of them works with this phone, it starts rebooting with all of them. I flashed back its original eeprom and the phone is alive again but still locked, finally i full flashed it with Tel cell Mexico firmware and tried read codes method, direct unlock method 1 and 2 and i obtain the same result. please assist me in the problem infinity. thanks |
04-30-2008, 02:30 | #8 (permalink) | |
with the new update i did the mg180 unlock, everything went ok, | |
Need To Unlock Lg Mg180 | lacasapc | FuriousGold | 0 | 12-31-2007 17:35 |
i need to unlock lg lx1200 | gorgans | Various CDMA/TDMA Cell Phones | 0 | 10-24-2005 00:13 |
help !!! need to unlock lg l1150 | royboy01 | LG | 0 | 08-18-2004 15:09 |
need to unlock LG usa version 4010 and 4050 | WIDE | LG | 3 | 04-02-2004 06:50 |
Need to unlock LG G5300 | loren | LG | 13 | 08-21-2003 12:45 |
