08-03-2009, 19:45 | #1 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 548443 Status: Offline Thanks Meter: 70 | Vodafone 228 DEAD while Unlocking! module v1.66 Device: Vodafone-228 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: -DE-P108C1V1.0.0B06 11 07 52 Feb 27 2008 11 07 52 04.12.00 18.26 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Programme\InfinityBox\Pana01\Vodafone-228_eeprom-static_20090803-203215.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Programme\InfinityBox\Pana01\Vodafone-228_eeprom-security_20090803-203217.B1E.bin reading eeprom-complete... file saved: C:\Programme\InfinityBox\Pana01\Vodafone-228_eeprom-complete_20090803-203223.B1E.bin reading additional data... file saved: C:\Programme\InfinityBox\Pana01\Vodafone-228_lock-area_20090803-203236.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area repair write error [00454800:0800]... error: write failed[00450000] Write Failed Finished, time used: 58 sec Remove/Install battery now ! HELLO , Can anyone tell me how to revive one Vodafone 228 that got dead during unlock process? Attached above is the LOG! Best Regards. |
08-03-2009, 21:56 | #3 (permalink) | |
Member: 548443 Status: Offline Thanks Meter: 70 | Quote:
Thanks for the quick reply to my question. The problems are these: 1. The handset is dead,so I cannot connect it when I try to do the unlock,but when I try to do Flash,it attempts to flash; 2.The Software Version is not found on the Support Site; 3. I do not know which flash files to choose. Could you please look again at the Unlock Log and check on Support Site and recommend to me which files I should choose? Thanks alot in advance. | |
08-04-2009, 11:54 | #4 (permalink) |
No Life Poster Join Date: May 2005
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks Meter: 341 | try flashing with this one Code: Vodafone-228_main_lp_VDF-P108C1FMB03-FrPtAr-GH01.B1M.bin |
The Following 2 Users Say Thank You to Softway For This Useful Post: |
08-04-2009, 20:29 | #5 (permalink) | |
I tried to flash back the Eeprom backup files as you suggested,and happily,the handset is back to life.However, I have unlocked it with another tool. Once again, thanks very much for your help.More grease to your elbows! | |
vodafone 228 error after unlock | chris2007 | FuriousGold | 5 | 04-01-2009 00:00 |
vodafone 228 can not unlock help plz | MUTUAL | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 01-15-2009 03:24 |
c1100 dead while unlocking | luckyfahad79 | LG | 13 | 05-30-2005 17:58 |
c975 dead while unlocking | shaikhboy | Smart-Clip | 4 | 04-27-2005 00:57 |
Mc-922 dead while unlocking | amitks_in | ARM9 BASED M62 / M62+ | 0 | 02-23-2005 15:13 |
