Old 10-26-2009, 18:22   #1 (permalink)
eyestrain's Avatar
Member: 237911
Thanks Meter: 632
Kf600 error unlocking
i have always encounter this error in unlocking KF600 on my infinity
COM6 [VCP5] selected
module  v1.68
Device: LG-KF600
Checking data, wait...
Action: flash write
Boot ...
s-gold3: D4
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
slowest
Set Baud Done
Connecting ...
flash: 0000:0000
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
loading data...
error: source buffer too small: 00000000 instead of 000035AE
backup critical area Done
Check memory ...
Check memory Done
Write ...
error: set erase range
error: erase is not confirmed
Write Failed
Finished, time used: 56 sec
Remove/Install battery now !
where is the error?
and by the way im using UST PRO as my interface coz i dont have time of modifying my cables on infinity,
but i will try while i am waiting for the answer
Old 10-27-2009, 17:23   #2 (permalink)
eyestrain's Avatar
Member: 237911
Thanks Meter: 632
now im using infinity as interface
COM35 [VCP3] selected
module  v1.68
Device: LG-KF600
Action: unlock
direct unlock
Boot ...
s-gold3: D4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
slowest
Set Baud Done
Connecting ...
flash: 0000:0000
Connecting Done
Check hardware ...
Check hardware Done
loading data...
Check memory ...
loading data...
error: operation terminated [00FF]
loading data...
loading data...
loading data...
error: can't read codes
error: not locked or unknown eeprom
Check memory Failed
Finished, time used: 36 sec
the first log was flashing eeprom it was error,
same with unlocking, using direct unlock and read unlock codes.
i think the infinity team dont know the answer?
ill have to figure it out on my own, i guess.
so goodluck to me
Old 10-27-2009, 17:26   #3 (permalink)
eyestrain's Avatar
Member: 237911
Thanks Meter: 632
i figure it out
http://forum.gsmhosting.com/vbb/show...6&postcount=41
anyone here who has this file pls upload it to non rapid link?
regards
Old 10-27-2009, 18:32   #4 (permalink)
NokiaMobileCare's Avatar
Member: 652870
Thanks Meter: 136
bro kf600 if u face error in infinty thn u can try Furious gold
Old 10-27-2009, 20:27   #5 (permalink)
eyestrain's Avatar
Member: 237911
Thanks Meter: 632
thanks Infinity :*
i am now on flashing mode,
thanks infinity for the information
regards
Old 10-29-2009, 07:10   #6 (permalink)
pine mobiles's Avatar
Member: 651119
Sonork: 100.1603096
Thanks Meter: 48
infinity team plz help lg kf600 after this prociger set is same errer
Old 11-01-2009, 19:43   #7 (permalink)
eyestrain's Avatar
Member: 237911
Thanks Meter: 632
what error did you encounter?
i try to use RPS but i encounter a lot of failure,
just put a full charge battery or at least 70% charge and try to flash again
Old 11-25-2009, 08:07   #8 (permalink)
Member: 76018
Thanks Meter: 59
I flashed phone too and have same error. Any ideas
Old 11-25-2009, 08:32   #9 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
Thumbs up kf600 problem
hi brother if u flash with n try to unlock n have a error
then u need this job
first uninstall ur module v1.68
install module v1.58
then try to unlock
i hope ur problem is solve
Old 11-25-2009, 11:08   #10 (permalink)
Member: 76018
Thanks Meter: 59
I use 1.71... wil check for 1.58 then
Old 11-25-2009, 13:22   #11 (permalink)
Member: 76018
Thanks Meter: 59
Same problem with 1.58...
Old 12-20-2009, 22:26   #12 (permalink)
Member: 132635
Thanks Meter: 360
only work v1.50 today i test
Old 01-04-2010, 14:48   #13 (permalink)
Member: 388046
Thanks Meter: 21
For me - not work.
Cable is OK
Interface is Infinity
Phone is locked to Orange
INFO:
Phone must be SWITCHED ON !
Connecting, wait...
Connection Ok
Read info...
software version:  KF600AT-01-V10b-232-005-OCT-06-2008+0
imei: 3520XXXXXXXXXXXXX
Done
Finished
KF600 PANA01 V1.50 LOG:
Device: LG-KF600
Action: unlock
direct unlock
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
slowest
Set Baud Done
Connecting...
flash: 0000:0000
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
backup critical area...
reading [eeprom-sta]...
loading data...
Check memory...
loading data...
error: operation terminated[00FF]
loading data...
loading data...
loading data...
Check memory Failed
Finished, Remove/Install battery now !
Time used: 40 sec
KF600 PANA01 V1.73 LOG:
module  v1.73
Device: LG-KF600
Action: "sp-unlock"
direct unlock
Boot ...
s-gold3: D4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
slowest
Set Baud Done
Connecting ...
flash: 0000:0000
Connecting Done
Check hardware ...
Check hardware Done
loading data...
Check memory ...
loading data...
loading data...
loading data...
loading data...
Check memory Failed
Finished, time used: 37 sec
Old 01-04-2010, 22:25   #14 (permalink)
Member: 76018
Thanks Meter: 59
I used Vygis later on...
kf600 error ENG. ADETUNJI FuriousGold 8 12-07-2009 17:46
kf600 error VELIKI VygisToolbox 1 10-19-2009 22:11
Kf600 Successfull Unlock bebiloku Infinity-Box 30 09-27-2008 16:14
Page generated in 0.25632 seconds with 9 queries
