04-02-2010, 10:55 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Vodafone 228fm- How to unlock Code: COM29 [VCP0] selected module v1.73 Device: Vodafone-228 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: VDF-P108C1FMB01-Hi-IN03 g3yBV2.1 11 11 59 04.12.00 18.26.11 08.0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-static_20100402-145948.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-security_20100402-145949.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-complete_20100402-145955.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_lock-area_20100402-150008.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 51 sec Remove/Install battery now ! when I check IMEI- it is different from the phone back cover So I repaired IMEI - Code: COM29 [VCP0] selected module v1.73 Device: Vodafone-228 Checking data, wait... Action: "repair imei" new imei: 355351021501398 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: VDF-P108C1FMB01-Hi-IN03 g3yBV2.1 11 11 59 04.12.00 18.26.11 08.0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-static_20100402-150405.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-security_20100402-150405.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-complete_20100402-150412.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_imei-area_20100402-150644.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_lock-area_20100402-150658.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found error: unknown firmware, read flash and send to support Check memory Failed Finished, time used: 3 min 12 sec Remove/Install battery now ! Finished |
04-03-2010, 19:19 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Did you tried to power-on phone with another sim card ? I suggest you to try phone with valid sim-card that can be accepted by network. |
06-23-2010, 07:43 | #4 (permalink) |
Junior Member Join Date: Jul 2004 Location: Bhubaneswar,orissa Age: 42
Member: 73011 Status: Offline Thanks Meter: 1 | Vodafone228FM Is thr any way to restore back imei of vodafone 228fm after full flash? I tried 2-3 times after flash but imei still same invalid one |
Vodafone v710 how to unlock and user code | chiragp | Vodafone Star | 30 | 06-25-2013 16:11 |
vodafone 710 how to unlock??? | mmanduri | Various | 9 | 02-29-2012 03:36 |
vodafone 527 how to unlock | saajith | Vodafone Star | 2 | 03-03-2009 10:22 |
panasomic X400 vodafone operator how to unlock | leroi | Infinity-Box | 2 | 05-04-2006 19:25 |
