Old 03-17-2010, 18:37   #1 (permalink)
geo_izak's Avatar
Member: 110575
Thanks Meter: 98
Vodafone 340 Pinouts...
Just want to share...
The Following 24 Users Say Thank You to geo_izak For This Useful Post:
Old 03-17-2010, 18:58   #2 (permalink)
Member: 1043909
Thanks Meter: 51,269
Thanks a lot, we will add this picture in next "Pinouts" update.
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 03-19-2010, 20:54   #3 (permalink)
CMV_2K's Avatar
Member: 9709
Thanks Meter: 32
thanks, it worked like a charm !!!
The Following User Says Thank You to CMV_2K For This Useful Post:
Old 06-06-2010, 14:23   #4 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 74
gr8 work broo..its v usefull
Old 10-18-2010, 15:13   #5 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,389
i got one vodafone 340 , plug was damage and i was search in forum i did not get test points for it , then i search in phone i got this
these are test point if cable's plug is not good
COM3 [VCP1] selected
module  v3.59
Action: "sp-unlock"
unlock method: smart fast
Model: Vodafone-340
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:D603:A00C
status: 01
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: BM35A1.V2.22.M00.02.42
Version: FOXLINK25_08B_HW
81 byte(s) read
imei: 35592203293536
connection Ok
186 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 1 min 47 sec
Remove/Install battery now !
here is test report
Faisal_Computer
The Following 2 Users Say Thank You to Faisal_Computer For This Useful Post:
Old 01-20-2011, 16:42   #6 (permalink)
Member: 7844
Thanks Meter: 181
Tx & Rx pin 2 & 3 is ok but GND we have 2 connectors .. should we connect 2 wires on pin 4 for ground ?
Old 01-20-2011, 18:05   #7 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,290
Hi,
You can use box pin-7 or pin-8 as a ground, but for best results use 7 + 8 together.
Old 01-20-2011, 21:53   #8 (permalink)
Member: 7844
Thanks Meter: 181
Originally Posted by InfinitySupport View Post
Hi,
ok so we use box pin 7 & pin 8 and connect them to both GND connectors ?
Old 01-21-2011, 05:50   #9 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 437
module v3.62
Action: "sp-unlock"
Model: Vodafone-340
19200 autodetect
CPU: MT6225
chip: 0001:BB03:A004
status: 01
Date: 2006.06.14
Version: 1.0
Version: BM35A1.V2.22.M00.02.44
81 byte(s) read
imei: 35592203431657
connection Ok
186 byte(s) read
reading data...
reading data #2...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 14 sec
use gw300 cable ok unlock with in14seconds
The Following 2 Users Say Thank You to adnanali For This Useful Post:
Old 01-21-2011, 09:23   #10 (permalink)
Member: 7844
Thanks Meter: 181
ye if i had gw300 lg cable i would have used it but i orderd it so i need to wait for its arrival lol
Old 03-10-2011, 13:21   #11 (permalink)
MIRPUR AJK's Avatar
Member: 725834
Thanks Meter: 919
good job bro thnkssssssssssssssssssssssssssssssssssssssss
Old 04-26-2012, 10:08   #12 (permalink)
haroon454's Avatar
Member: 653398
Sonork: 100.1619594
Thanks Meter: 613
use rx tx
COM10 [VCP0] selected
module v4.13
Action: "sp-unlock"
Model: Vodafone-340
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:F403:A00D
status: 01
Date: 2006.06.14
Version: 1.0
Version: BM35A1.V2.22.M00.02.34
81 byte(s) read
imei: 35592203098995
connection Ok
186 byte(s) read
reading data...
reading data #2...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
The Following User Says Thank You to haroon454 For This Useful Post:
Old 06-24-2012, 19:37   #13 (permalink)
Member: 95476
Thanks Meter: 184
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:4003:A00F
status: 01
Date: 2006.06.14
Version: 1.0
81 byte(s) read
imei: 35592203450108
connection Ok
186 byte(s) read
reading data...
reading data #2...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 1 min 22 sec
Old 06-29-2012, 10:01   #14 (permalink)
Member: 1043909
19200 autodetect
CPU: MT6225
high speed boot On
status: 01
Date: 2006.06.14
Version: 1.0
81 byte(s) read
connection Ok
186 byte(s) read
reading data...
reading data #2...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Old 10-25-2012, 10:18   #15 (permalink)
balar's Avatar
Member: 213681
Thanks Meter: 108
Hi
If you want unlock this phone via cable:
Use infinity box and LG GM750 Cable from vigis box
Tested 100% successful
The Following User Says Thank You to balar For This Useful Post:
vodafone 340 pinout S.Leo Infinity-Box 20 05-08-2013 22:28
Vodafone 340 unlock[ANSWERED & SOLVED] msa Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 8 10-23-2012 14:41
15 Feb 2010: Micromax-X332 model supported, Vodafone-340 model under test YellowBoss Infinity-Box 19 02-18-2010 14:43
Infinity-Box: non-stop updates: Micromax-X332 model supported, Vodafone-340 model... YellowBoss Service Products News & Updates 0 02-15-2010 15:12
Vodafone 340 ct3im FuriousGold 2 01-29-2010 18:02
Page generated in 0.49944 seconds with 8 queries
