07-03-2012, 04:45
#1 (permalink)
| Product Supporter
Join Date: Mar 2009 Location: from-(PH)-Silence all in one Age: 6
Member: 990711
Sonork: 100.1597405 Thanks: 2,084
| VODAFONE - 340 SIM BLOCK, need help team. VODAFONE - 340 SIM BLOCK, need solution team
how to change imei Quote:
Action: "repair imei"
Model: Vodafone-340
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
baud set to: 115200
Phone detected, wait...
imei-1: 355922034257424
imei write method: mode-1 AT
new imei-1: 353548006145115
Verification failed, what to do:
1. Power-Off phone
2. Press software "Write" button
3. Power-On phone
operation failed !
Finished, time used: 28 sec
Remove/Install battery now !
| Quote:
COM97 [ProlificSerial2] selected
module v4.35
Device: Vodafone-340
Operation: write 357988021430512
mode-2 META
interface: META_DLL_v6.1108.00
Connect...
error: can not connect to device: 004D:BootROM security check fail
error: last error: 004D:BootROM security check fail
Shutdown...
done
error: operation failed
Finished, time used: 12 sec
| Quote:
module v4.35
imei write method: mode-3 flash
new imei: 332201352704285
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:6403:A00D
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_44.BIN
project-id: BM35A1.V2.22.M00.02.44, 00000000
code offset: 00000000
ffs offset/size [01]: 00B80000/00480000
TCL-ID is absent
ffs/eeprom address assigned: 00B80000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__ffs...
file saved: C:\InfinityBox\MModule\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__ffs_20120703-114117.B0E.bin
Backup required data Done
====> Patch required data ...
imei is not detected !
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "imei" procedure again
If imei can't be detected:
1. make "complete" ffs/eeprom format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "imei" procedure again
If imei can't be detected: read flash and send to support: support@infinity-box.biz
Patch required data Fail
file saved: c:\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__system_log__00000000_20120703-114123.B0X.bin
Finished, time used: 2 min 26 sec
Remove/Install battery now ! | |
