03-04-2010, 22:43 | #1 (permalink) |
No Life Poster Join Date: Sep 2008
Member: 868940 Status: Offline Thanks Meter: 90 | vodafone 340 unlock.. 1.which software version? 2.which module of software i need? 3.which cable i need? or pinout thankx. regards |
03-06-2010, 23:16 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: http://www.infinity-box.com/news.php 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software If you will have any problems do not hesitate to contact us anytime. |
Vodafone 340 unlock[ANSWERED & SOLVED] | msa | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 8 | 10-23-2012 14:41 |
vodafone 340 unlock using pin finder | ZIYAAD STRYKER | Infinity-Box | 2 | 03-23-2010 20:19 |
vodafone 340 unlock.. | dawah telecom | FuriousGold | 9 | 03-11-2010 08:17 |
