11-06-2012, 17:50 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | vodafone 340 unlock mmodule 4.40 broken old mmodule v3.76 works but latest mmodule v4.40 faulty with this phone, please fix it. old ok: COM6 [VCP1] selected module v3.76 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:EF03:A005 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.44 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203609267 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 22 sec Remove/Install battery now ! ============================ new version 4.40 broken: COM6 [VCP1] selected module v4.40 Device: Vodafone-340 Checking data, wait... Operation: SP-unlock unlock method: read codes interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can not connect to device: 004D:BootROM security check fail error: last error: 004D:BootROM security check fail Shutdown... done error: operation failed Finished, time used: 8 sec Remove/Install battery now ! please dont tell me try other way because I did, I tried all possible ways with 4.40 and none of them work, after I use old mmodule and right away ok. |
The Following User Says Thank You to mrfixit For This Useful Post: |
11-07-2012, 15:32 | #2 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | I find posts here with "004D:BootROM security check fail" for 4.35 and 4.38 successful unlocks of Vodafone 340 are with 3.19 up to 4.13 somewhere between 4.13 and 4.35 is a fail. |
12-01-2012, 14:53 | #6 (permalink) |
No Life Poster Join Date: Oct 2005 Location: pakistan
Member: 188374 Status: Offline Sonork: 1000.2 Thanks Meter: 203 | ==== [12/1/2012 6:34:07 PM] ==== COM9 [VCP0] selected module v3.76 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:EC03:A007 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.42 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203290789 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! |
The Following User Says Thank You to papoo For This Useful Post: |
01-11-2013, 13:39 | #7 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Dhaka,Bangladesh
Member: 80250 Status: Offline Sonork: 100.1602959 Thanks Meter: 76 | COM10 [VCP0] selected module v4.09 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:C603:A00F status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.44 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203508859 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 16 sec Remove/Install battery now ! |
03-06-2013, 10:17 | #8 (permalink) | |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Quote:
COM10 [VCP0] selected module v4.43 Device: Vodafone-340 Checking data, wait... Operation: SP-unlock unlock method: smart fast interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can not connect to device: 004D:BootROM security check fail error: last error: 004D:BootROM security check fail Shutdown... done error: operation failed Finished, time used: 20 sec Remove/Install battery now ! | |
03-06-2013, 14:50 | #11 (permalink) | |
03-07-2013, 13:02 | #13 (permalink) |
Member: 148032 Status: Offline Thanks Meter: 415 | ideed with v3.76 works: Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3703:A005 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.44 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203452043 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! |
The Following User Says Thank You to dragosgsm For This Useful Post: |
