12-23-2013, 11:50 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | vodafone 340 unlock problem unlock method: smart fast COM4 [VCP0] selected module v4.39 Device: Vodafone-340 Checking data, wait... Operation: SP-unlock unlock method: smart fast interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can not connect to device: 004D:BootROM security check fail error: last error: 004D:BootROM security check fail Shutdown... done error: operation failed Finished, time used: 6 sec Remove/Install battery now ! unlock method: standard COM4 [VCP0] selected module v4.39 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:A303:A007 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_23_M 00_02_35.BIN project-id: BM35A1.V2.23.M00.02.35, 00000000 code offset: 00000000 ffs offset/size [01]: 00B80000/00480000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00B80000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35__ffs... file saved: C:\InfinityBox\MModule\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35__ffs_20131223-164649.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: EC257E25082501:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35__system_log__00000000_20131223-164718.B0X.bin Finished, time used: 4 min 5 sec Remove/Install battery now ! need help |
01-04-2014, 07:07 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | flash with this firmware and unlock Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 04_M00_02_44_2010-09-03_En_Ru_Gr_Ro_Shqip.B0M.bin |
