Unlock Server
Old 04-23-2012, 09:30   #1 (permalink)
.:HeRo:.'s Avatar
Member: 530410
Sonork: 100.1582823
Thumbs up Vodafone 345 UNLOCKED
Vodafone-345
COM7 [Serial2] selected
module  v3.75
Device: Alcatel-543X
Checking data, wait...
Action: rebuild security area
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:F203:A009
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 98006F00000004:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
otp offset: 01FE0000
Initialize Done
====>  Set baud ...
115200
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\InfinityBox\MModule\backup_security\id.8280184E.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32_F3.BIN_9096F062].rpl
New firmware found (v.3.75, database date: 12.02.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: support@infinity-box.biz or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 8280184E
rom info ver: 07
sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32_F3.BIN
project-id: MAUI.08A.W08.40.SP1.V32.F3, 62F09690
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID identification
version: 263
provider: 543X-2AVDPT1
customization: CN26FG02
customization: XN26FG02
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
version is not found in database: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32_F3.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 00006F50->00006C50
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
identification header detected
customization: XN26FG05
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
done
done
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
original imei: 35982003032543
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
file saved: C:\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32_F3__system_log_8280184E_9096F062_20120423-112253.B0X.bin
Finished, time used: 5 min 14 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to .:HeRo:. For This Useful Post:
Old 04-23-2012, 10:35   #2 (permalink)
YellowBoss's Avatar
Member: 1043909
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:06
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 07-09-1999 22:08
Page generated in 0.36235 seconds with 11 queries
