03-07-2011, 14:14 | #1 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 624567 Status: Offline Thanks Meter: 256 | vodafone 345 unlocking problem module v3.78 Device: Vodafone-345 Checking data, wait... advanced flash detection disabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 chip: 0011:6308:A00C status: 01 warning: unknown or damaged hardware boot packet size: 0400 error: bootcode load error: A0 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 18 sec Remove/Install battery now ! |
03-07-2011, 14:22 | #2 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 992 | Quote:
U have to check its pcb. But first try with change cable or low speed i think it will be work. | |
03-07-2011, 17:33 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum |
03-07-2011, 17:34 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Just rotate my Alcatel C701 picture for 180 and you will get a pinout. |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
