Old 11-26-2007, 08:17   #1 (permalink)
tarunvishal's Avatar
Member: 308296
Thanks Meter: 152
infinity team can u read my problem
sir i a zt678 the problem is set restart without sim so i m not format the set beacause set not goes in test mode set on when i m press power on button when software set press power button sir i mread backup of flash so i m see this message
warring proberly flash chip empety earased and after reading i m not found the any name of flash Here is log
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: read NOR flash
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6205:8B00]...
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E221A2201:FFFFFF00000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support with detailed description of problem,
attach the next files in your e-mail:
1. E:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. E:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 00400000
detect device identification, method #1...
detection phase #1...
detection phase #2...
warning: identification information not found, possible reasons:
.old firmware type w/o identification data
.damaged firmware
.damaged hardware
detect device parameters finished
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-003FFFFF...
Can't detect eeprom area
Do you want to use standard eeprom address: 00380000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard eeprom address selected by user
detecting eeprom size...
eeprom size: 00080000
eeprom chip: 00
eeprom area: 00000000:00380000-003FFFFF
reading [flash]...
warning: wrong data size at 0x00196C00, retry...
read error recovered
warning: wrong data size at 0x001D4400, retry...
file saved: E:\Program Files\InfinityBox\ChineseMiracle\Zt678\backup_flas h_20071126-124205.B0M.bin
Finished, time used: 499 sec
Remove/Install battery now !
sir after all the backup is only 6Kb and not define any name of falsh file its show only this name so plz tell how to i m find a proper flash file for this set the name of file is backup_flash_20071126-124205.B0M
Old 11-26-2007, 08:19   #2 (permalink)
Member: 308296
Thanks Meter: 152
sir two cpu in the set is MT6205BA or 6226BA
Old 11-26-2007, 08:33   #3 (permalink)
Member: 308296
Thanks Meter: 152
sir i m when read first time of the backup of set so i mread of this name file DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]_20071116-154219.B0M is only 3mb sir plz give me the advise whoes the best flash file for this set th
Thanks in advance
Old 11-26-2007, 19:04   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
The best flash file is the file with firmware version name similar to original firmware version name.
Can my Infinity Team can add this model? Kashif Khan Infinity-Box 0 04-30-2009 23:48
Infinity Team Please help with my Infinity.... ASHRIFF Infinity-Box 1 03-10-2008 16:51
@Infinity Team :How to read or reset phonelock for Bird V10 anhtam Infinity-Box 3 07-16-2006 11:02
Infinity Team can update Vk900 KAITA Infinity-Box 0 12-19-2005 10:49
Infinity Team Can You Help Me Quick ?? distefano Infinity-Box 2 11-04-2005 18:58
Page generated in 0.14971 seconds with 9 queries
