Old 12-08-2007, 04:34   #1 (permalink)
Member: 328416
Thanks Meter: 42
LG KG200 LG LOGO Diaplay Only then Off
Hello, I have here LG KG200 the phone dead but after I flashed then power it On only LG Logo will display then few second it will automatically shutoff... how can I revive it please help... TIA
Old 12-08-2007, 05:12   #2 (permalink)
G*Mughal*G's Avatar
Member: 133099
Sonork: 100.1582860
Thanks Meter: 18
Brother try format ffs if not work then flash it with latest version flash file
Old 12-08-2007, 08:05   #3 (permalink)
Member: 328416
Thanks Meter: 42
Yahoooo... I finally made it... thanks Infinity.........
As I had observed in KG200.. never do Format FFS because it will kill your phone... but the solution is Flash Firmware and Eeprom...
Reminder in Flashing...
1. Do not check Smart write "verify before write"
2. Do not Check Format FFS during write
Old 12-08-2007, 08:31   #4 (permalink)
G*Mughal*G's Avatar
Member: 133099
Sonork: 100.1582860
Thanks Meter: 18
ok thanks for information.... will try when stuck with this problem
anyhow in my case simply format the phone worked and set alive...
Old 12-08-2007, 10:21   #5 (permalink)
Member: 128745
Thanks Meter: 16,936
thankyou for your good test results
Old 12-11-2007, 14:18   #6 (permalink)
..::: Naveed :::..'s Avatar
Member: 352237
Sonork: 100.1577161
Thanks Meter: 605
Can we use any firmware of kg 200 ?
Old 12-11-2007, 14:39   #7 (permalink)
tshcom's Avatar
Member: 224312
Thanks Meter: 13
thanks brother...........
Old 12-12-2007, 07:45   #8 (permalink)
Member: 130995
Thanks Meter: 35,227
You can download KG200 flash files from Infinity-Box support area use it for flashing.
Old 12-12-2007, 08:32   #9 (permalink)
~mr_Ten$ion~'s Avatar
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
Thanx for Test Report ...... Anyways i hve also an Easy Way to Slove Dis Prob ...... jst in a Few Sec......
Old 12-12-2007, 08:35   #10 (permalink)
Member: 352237
Sonork: 100.1577161
Thanks Meter: 605
I did not meant that can i use any other flash files in kg200 i asked can i flash this phone with any kg 200 flash files
Old 09-04-2008, 09:43   #11 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
where is ur solution boss.
Old 09-04-2008, 13:20   #12 (permalink)
Member: 130995
Tested solution with Infinity-Box already posted in current thread.
Please, check current thread from begin.
Old 09-04-2008, 17:44   #13 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
very good test reports bother.
its working for many members.
Old 10-18-2008, 06:28   #14 (permalink)
gsmsmile's Avatar
Member: 703206
Sonork: 100.1601193
Thanks Meter: 412
bro i have same problem but set is still this position please help me how i can do please
Old 10-18-2008, 06:40   #15 (permalink)
Deepakranasaria's Avatar
Member: 388207
Thanks Meter: 221
great work bro thanks for the test report
3600s NOKIA only then OFF pls HELP..!! xannix_7575 Nokia Base Band 5 ( BB-5 ) 2 01-01-2010 10:55
5310 nokia only then off clyderz88 Nokia Base Band 5 ( BB-5 ) 3 05-01-2009 05:45
unlocking LG-cg225 cellrepairus NSPRO 0 04-30-2008 22:37
LG KG200 off on LG startup logo asad_nomy7 Infinity-Box 2 04-09-2008 18:45
LG U8120 ON 3/4 seconds then OFF MOB~Tec Uk LG 3G (USB-Smart) 5 05-04-2006 16:27
Page generated in 0.29898 seconds with 10 queries
