12-23-2009, 14:58 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: morroco
Member: 245026 Status: Offline Thanks Meter: 382 | COM8 [VCP0] selected module v2.96 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9F03:A00F status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:FFFFFF00000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... . search rom info finished searching rom info... . search rom info finished searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs address can not be detected, value from database assigned: 01800000/00800000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 98006F00000004:FFFFFF00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:FFFFFF00000000 Finalization Done Finished, time used: 76 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to sassa_01 For This Useful Post: |
12-23-2009, 16:19 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to use this new software: http://www.infinity-box.com/download...e_v3.00_v3.rar Make unlock first. If phone still can not power-on you can flash phone with firmware from support area. Waiting for your results. |
12-23-2009, 17:12 | #5 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: campioni del mondo
Member: 235881 Status: Offline Thanks Meter: 221 | use new version unlock without problems Quote:
The Following User Says Thank You to GSM PAVIA For This Useful Post: |
12-23-2009, 20:12 | #6 (permalink) | |
Member: 245026 Status: Offline Thanks Meter: 382 | Quote:
708X-2EVDPT1-117B_XN17FG72_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MA UI_08A_W08_40_SP1_V32_2009-09-10_En_Fr_Es_De_Pt_Vodafone-541.B0M.bin White screen | |
12-23-2009, 20:55 | #8 (permalink) |
No Life Poster Join Date: Oct 2008 Location: WHERE THE WORLD ENDS
Member: 885625 Status: Offline Sonork: 100.1589108 Thanks Meter: 2,432 | YOU PHONE IS ALIVE MAN SPANISH-----toque en cualquier sitio de la pantalla con el lapiz tactil para empezar la calibracion. HERE IS ENGLISH TRANSLATION---TOUCH YOUR PHONES SCREEN ANYWHERE WITH PEN TO MAKE CALIBRATION. I HOPE NOW YOU CAN RELAX,SUUNNYY |
12-24-2009, 19:17 | #10 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 572171 Status: Offline Thanks Meter: 23 | yess new up date m module is very good is nothing happond with voda 541 lobster s621 alcatel s319 t mobile alcatel 660 some off tham done some off tham dead but after flash and after that unlock done very nice update best regard for infinity team |
03-29-2010, 10:49 | #11 (permalink) |
Junior Member Join Date: Jul 2008 Location: accra_ghana
Member: 823071 Status: Offline Sonork: [email protected] Thanks Meter: 0 | pl can sameone help me to unlock nokia 1661c and 1662c |
03-29-2010, 14:27 | #12 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | |
04-10-2010, 13:13 | #13 (permalink) |
No Life Poster Join Date: May 2003 Location: King of Nokia Age: 47
Member: 28531 Status: Offline Thanks Meter: 90 | hello friends.. i made change vodafone 541 later my phone is dead.but now is workig.. How make it : Select infinty MModule- select module 541- Repair- "Repair Security Area" everthing is OK Good luck.. COM3 [VCP3] selected module v3.34 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3103:A007 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is damaged, recalculation required rom info detection finished TCL-ID detection... TCL-ID detection done device-id: F453F568 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17B provider: 708X-2EVDPT1 customization: CN17FG72 customization: XN17FG72 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: startup code area #1 startup code area #1 fixed sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN17B140 warning: customization name is unknown name table[01] #7000000 detected customization: CN17FG72 customization name adjusted customization: CN17FG72 customization name adjusted customization detected: CN17FG72 customization: CN17FG72 flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN17B140 warning: customization name is unknown name table[01] #7000000 detected customization: CN17FG72 customization name adjusted customization: CN17FG72 customization name adjusted customization detected: CN17FG72 customization: CN17FG72 flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35400703211403 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_F453F568_E8F450A0_20100410-150453.B0X.bin Finished, time used: 3 min 56 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to yargich For This Useful Post: |
07-30-2010, 12:24 | #14 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1356538 Status: Offline Thanks Meter: 0 | After two months the screen has gone white completely, but everything is ok except this, i can blindly turn on the music, or navigate menu (blindly - as the whole screen is white), recieve calls.. so any solution to this? please reply.. need ur help |
07-30-2010, 19:38 | #15 (permalink) | |
Why screen become white ? | |
Vodafone 541? | ecsike | Infinity-Box | 75 | 04-16-2011 09:36 |
how can i flash vodafone 541....[SOLVED] | lad2 | PolarBox 3 | 3 | 03-29-2010 18:49 |
has any one unlocked Vodafone 541 | sniper007 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 18 | 01-16-2010 10:55 |
Vodafone 541 unlock? | Petyo | Easy-Unlocker | 16 | 12-10-2009 16:27 |
Vodafone 541 - MEDIATEK MT6235 chipset??? | hhhansen | Chinese Models & Cloned Phones | 0 | 09-29-2009 20:01 |
