Old 12-12-2009, 16:55   #1 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,693
Talking vodafone 541 (alcatel) unlocked 100%with infinity box
thanx thanx thanx INFINITY BOX for your job
COM6 [VCP0] selected
module v2.99
Device: Vodafone-541
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001403:A001
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000003:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.5C21A 4CD.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 5C21A4CD
rom info protocol ver: 07
ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
ver. sw 2: MAUI.08A.W08.40.SP1.V32, A050F4E8
code offset: 00020000
ffs offset/size: 01800000/00800000
TCL-ID identification
version: 17B
provider: 708X-2EVDGB1
customization: CN17FC75
customization: XN17FC75
TCL-ID identification done
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00000000000000
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_5C21A4CD_E8F450A0_20091212-164300.B0X.bin
Finished, time used: 338 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 10 Users Say Thank You to genci titi 2002 For This Useful Post:
Old 12-12-2009, 17:02   #2 (permalink)
The_Dj's Avatar
Member: 178790
Sonork: 100.1593063
Thanks Meter: 1,234
thx u for Share.
IB the Best.
Old 12-13-2009, 06:56   #3 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
Thank you ,
Every Test report is Very important for infinity team for improving software ability !!
Faisal_Computer
The Following User Says Thank You to Faisal_Computer For This Useful Post:
Old 12-13-2009, 07:03   #4 (permalink)
vodafoneserver's Avatar
Member: 617174
Sonork: 100.1622609
Thanks Meter: 579
Good information bro ...
The Following User Says Thank You to vodafoneserver For This Useful Post:
Old 12-14-2009, 15:40   #5 (permalink)
Member: 856869
Sonork: +37744510000
Thanks Meter: 30
pin out for vodafone 541 please any picture
Old 12-16-2009, 09:25   #6 (permalink)
shaheen15's Avatar
Member: 137426
Thanks Meter: 50
which cable did you use
Old 12-17-2009, 00:49   #7 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
you can find pinouts in infinity shell...
Old 12-17-2009, 07:47   #8 (permalink)
md.nazmul's Avatar
Member: 648428
Thanks Meter: 846
Good info thankxxxxx
Old 12-20-2009, 15:23   #9 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 12-21-2009, 14:32   #10 (permalink)
Member: 841640
Thanks Meter: 86
Big thanks Infinity team. I've just succesfully unlocked a Vodafone 541
COM3 [VCP0] selected
module v2.99
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:A503:A007
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.D58AB 7DA.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl
TCL-ID detection...
device-id: D58AB7DA
version: 17B
provider: 708X-2HVDGB1
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_D58AB7DA_E8F450A0_20091221-132030.B0X.bin
Finished, time used: 256 sec
The Following User Says Thank You to lovist2 For This Useful Post:
Old 05-26-2010, 12:57   #11 (permalink)
Member: 319322
Thanks Meter: 14
thanx infinity team for such a nice support
[COM8 [VCP0] selected
module v3.38
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:2903:A008
status: 01
Boot Done
flash: 98006F00000004:09EA0000000000
otp offset: 01FE0000
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.AF264 262.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_AB686FA6].rpl
TCL-ID detection...
device-id: AF264262
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, A66F68AB
ffs offset/size [01]: 01800000/00800000
version: 17G
customization: CN17FC92
customization: XN17FC92
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
done
done
original imei: 35908103313682
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_AF264262_AB686FA6_20100526-172245.B0X.bin
Finished, time used: 5 min 43 sec
The Following User Says Thank You to anhalnikki For This Useful Post:
Old 05-26-2010, 13:04   #12 (permalink)
unicomtogo's Avatar
Member: 660737
Thanks Meter: 105
Originally Posted by InfinitySupport View Post
Hello,
vodafones are unlocked here. since we asked for vodafone 236 unlock.
but till now anything
Old 05-31-2010, 11:52   #13 (permalink)
unicomtogo's Avatar
Member: 660737
Thanks Meter: 105
Hello,
is all provider id supported?
is this ID supported?
708X-2EVDGB1
Coz i try to unlock; all is done but the phone was not unlocked.
Old 06-01-2010, 22:30   #14 (permalink)
Member: 130995
708X-2EVDGB1
It should be no problems with any provider.
What MModule software version you have used ?
Old 07-12-2010, 07:46   #15 (permalink)
Member: 408058
Thanks Meter: 371
unlock with pad finder
module v3.46
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:E103:A007
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.F2CAF 93A.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_AB686FA6].rpl
TCL-ID detection...
device-id: F2CAF93A
rom info ver: 07
version: 17G
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
original imei: 35400703434729
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_F2CAF93A_AB686FA6_20100712-113712.B0X.bin
Finished, time used: 6 min 24 sec
The Following User Says Thank You to samalik For This Useful Post:
Vodafone 123 succesfully unlocked by infinity somratjisan Infinity-Box 4 12-09-2010 09:49
first in the world unlock by infinity box vodafone 541 lilong_lee Infinity-Box 7 03-11-2010 08:57
unlock vodafone 541 after unlock we need calibration tuoch sceer lilong_lee Infinity-Box 0 02-23-2010 08:04
vodafone 541 succes unlock via code[ANSWERED & SOLVED] ayhen42 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2 02-09-2010 14:37
vodafone 226 by sagem unlock 100%by infinity box genci titi 2002 Infinity-Box 2 08-21-2008 13:14
Page generated in 0.32704 seconds with 9 queries
