Vodafone 541 cable? I need to unlock the vodafone 541, but what cable does it use? i have pinfinder but cant find the pins with it? |
use alcatel c701 pinouts working sweet |
tried that pinout (c701) it dont work |
Hello, If phone can not be connected via bottom connector you can try to use test-points under battery. |
can you someone tell me what cable is used using the pinfinder. i have being using the L10c cable, mayeb this is the wrong cable? |
You can select in PinFinder L10C 2x5 cable and select pinout from list like C701. It is need to check that cable fit inside phone connector well. |
HERE IS A LOG COM9 [VCP1] selected module v2.96 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1903:A00B status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: E:\Archivos de programa\InfinityBox\MModule\backup_security\id.87 331388.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_064A906B].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 87331388 rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, 6B904A06 address offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 17C provider: 708X-2FVDES1 customization: CN17FE82 customization: XN17FE82 TCL-ID identification done ffs address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FE82 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FE82 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: E:\Archivos de programa\InfinityBox\MModule\backup_security\Vodaf one-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_87331388_064A906B_20091126-224302.B0X.bin Finished, time used: 289 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
Hello , i just did vodafone 541 100% with infinity. Here is the log: COM20 [VCP0] selected module v2.96 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:EC03:A00E status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Programas\InfinityBox\MModule\backup_security\i d.74B3F5E9.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_064A906B].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 74B3F5E9 rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, 6B904A06 address offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 17C provider: 708X-2FVDES1 customization: CN17FE82 customization: XN17FE82 TCL-ID identification done ffs address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FE82 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FE82 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Programas\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_74B3F5E9_064A906B_20091127-163929.B0X.bin Finished, time used: 324 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! B.R. Kg-gsm (Karyn) |
COM29 [VCP0] selected module v2.98 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:8C03:A00E status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.DFFAA 37A.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: DFFAA37A rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 17B provider: 708X-2EVDPT1 customization: CN17FG72 customization: XN17FG72 TCL-ID identification done ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FG72 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FG72 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_DFFAA37A_E8F450A0_20091206-101855.B0X.bin Finished, time used: 362 sec Remove/Install battery now ! 100% tested and working, thanks a lot infinity team. great work. |
COM4 [VCP0] selected module v2.98 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7103:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.94AD3 5D4.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 94AD35D4 rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 17B provider: 708X-2EVDPT1 customization: CN17FG72 customization: XN17FG72 TCL-ID identification done ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FG72 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FG72 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_94AD35D4_E8F450A0_20091207-160159.B0X.bin Finished, time used: 372 sec Remove/Install battery now ! |
same cable alcatel s320 |
Vodafone 541 unlock cable 100% work! Test point! |
COM3 selected module v3.02 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:FF03:A002 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.B06B7 D58.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: B06B7D58 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17B provider: 708X-2GVDGB1 customization: CN17FC75 customization: XN17FC75 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: disabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: disabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FC75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FC75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_B06B7D58_E8F450A0_20100421-173833.B0X.bin Finished, time used: 8 min 40 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
