05-30-2010, 08:38 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: UKR
Member: 359895 Status: Offline Sonork: 100.107909 Thanks Meter: 137 | Vodafone 541 Dead 708X-2CALRU1-16E_XN16BN24_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-08-28_En_Fr_De_Ru_Ua_simfree.B0M.bin 708X-2CALRU1-16E_XN16BN24_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-08-28_En_Fr_De_Ru_Ua_simfree_v2.B0M.bin backup FF RapidShare: 1-CLICK Web hosting - Easy Filehosting help with repair? |
05-30-2010, 22:28 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Did You restored the backup firmware and the phone still can't power on? |
The Following User Says Thank You to Burebista For This Useful Post: |
06-02-2010, 08:34 | #8 (permalink) | |
Member: 359895 Status: Offline Sonork: 100.107909 Thanks Meter: 137 | Quote:
Code: module v3.39 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:5803:A009 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.7427F401.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN_BEC882F7].rpl rom info detection finished ==================== New firmware detected (v.3.39, database date: 24.05.2010): JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== TCL-ID detection... TCL-ID detection done device-id: 7427F401 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, F782C8BE code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17Q provider: 708X-2EVDGB1 customization: CN17FC92 customization: XN17FC92 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... version is not found in database: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 00006F50->00006C54 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN17Q140 warning: customization name is unknown name table[01] #7000000 detected customization: CN17FC92 customization name adjusted customization: CN17FC92 customization name adjusted customization detected: CN17FC92 customization: CN17FC92 customization: XN17FC92 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN use default security area (sec info, hash) pattern ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN17Q140 warning: customization name is unknown name table[01] #7000000 detected customization: CN17FC92 customization name adjusted customization: CN17FC92 customization name adjusted customization detected: CN17FC92 customization: CN17FC92 customization: XN17FC92 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN use default security area (sec info, hash) pattern ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908103231336 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32__system_log_7427F401_BEC882F7_20100602-105109.B0X.bin Finished, time used: 4 min 26 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! | |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
