Old 12-10-2009, 11:20   #1 (permalink)
Member: 474339
Thanks Meter: 44
vodafone 541 flashing with infinity but no network
hi infinity team..i tried to flash 541 but now it has no network.
i wrote eeprom from support and flash but no network
then i wrote working fone eeprom and flash from support but still same
here is the log
COM5 [VCP0] selected
module v2.97
Device: Vodafone-541
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:0503:A008
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000004:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.BDD16 7CC.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_A8667CC5].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: BDD167CC
rom info protocol ver: 07
ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
ver. sw 2: MAUI.08A.W08.40.SP1.V32, C57C66A8
address offset: 00020000
ffs offset/size: 01800000/00800000
TCL-ID identification
version: 16G
provider: 708A-2CTLGT3
customization: CN16NT24
customization: XN16NT24
TCL-ID identification done
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is valid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
customization: XN16NE21
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00000000000000
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_BDD167CC_A8667CC5_20091210-101128.B0X.bin
Finished, time used: 342 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
then i unlocked...but no success..
plz help
Old 12-10-2009, 14:36   #2 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
what was the condition of mobile ?
and why you flash the mobile ?
is it dead , its yes then how its become dead , maybe its hardware problem
Faisal_Computer
Old 12-10-2009, 14:40   #3 (permalink)
Member: 474339
Thanks Meter: 44
mobie was ok before..
suddenly my pc restarted so i flashed it...
only software problem
Old 12-10-2009, 14:47   #4 (permalink)
Member: 151871
if phone was ok then what were you doing with that mobile ?
and what was you doing when your pc restart ?
Faisal_Computer
Old 12-10-2009, 18:16   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
@m_naeem
did you tried to make 112/emergency call w/o sim card ?
What is the results ?
Old 12-10-2009, 21:22   #6 (permalink)
Member: 474339
Thanks Meter: 44
i was trying to unlock the cell sir...
no sir cannot call 112...
Old 12-11-2009, 11:12   #7 (permalink)
Member: 130995
Hello,
You can try to flash phone with different flash files from support area and see results, but if phone can not make 112/emergency call - it's hardware problem in most cases.
Old 12-13-2009, 05:14   #8 (permalink)
Member: 474339
Thanks Meter: 44
my mistake,i flashed with 708a, now i flashed with 708x..its ok now thnx infinityteam...but there is not portuguese langauage in flashfile..
Old 12-13-2009, 08:33   #9 (permalink)
Member: 151871
its ok ..... if you have any phone which have that your desire language please read full flash and send it to infinity support !!
Faisal_Computer
The Following User Says Thank You to Faisal_Computer For This Useful Post:
LG KG130 unlock with hwk but no network denard HWK 1 06-04-2013 11:47
help vodafone 332fm flash with infinity godwin Infinity-Box 2 03-26-2010 18:41
Vodafone 541, flashed with 708a [CLOSED] hugmax PolarBox 3 6 12-28-2009 22:12
Successfully unlock and flash ALCATEL C701X But no network khawar Infinity-Box 9 12-12-2009 11:49
Kg195 Flash With Infinity But.........help sairat Infinity-Box 10 02-04-2008 18:48
Page generated in 0.22568 seconds with 9 queries
