Old 09-24-2010, 11:20   #1 (permalink)
Boshko_Alfa's Avatar
Member: 472933
Sonork: 100.1590967
Thanks Meter: 1,331
Vodafone 541 a.k.a. AlcOT708 - warning: wrong data size at 0x0004C440, retry...
COM11 [VCP0] selected
module v3.51
Device: Alcatel-708X, 708A
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:7E03:A001
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000004:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
otp offset: 01FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
error: too many retries during read operation
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
error: no any expected answer
error: can't read startup code area #1
ffs/eeprom address assigned: 01800000
startup code area #1 check...
warning: startup code area #1 data is invalid
error: startup code area #1 can't be fixed
sec info (detailed) detection...
searching sec info#1...
error: unexpected termination/freez: 00000000
search sec info#1 finished
error: connection lost
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log__064A906B_20100924-121622.B0X.bin
Finished, time used: 1 min 34 sec
Remove/Install battery now !
why where is the problem?
i have many unlocked but this is totaly new branded phone and don't wanna to unlock.
Old 09-24-2010, 12:22   #2 (permalink)
Member: 472933
Sonork: 100.1590967
Thanks Meter: 1,331
with lower speed - sucesfull
module v3.51
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: 01
Boot Done
Initialize Done
====> Set baud ...
230400
Set baud Done
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.0DCB0 779.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_064A906B].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 0DCB0779
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, 6B904A06
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID identification
version: 17C
provider: 708X-2EVDMK1
customization: CN17FW80
customization: XN17FW80
TCL-ID identification done
TCL-ID is present
startup code area #1 fixed
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35908103290378
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_0DCB0779_064A906B_20 100924-132041.B0X.bin
Finished, time used: 5 min 10 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to Boshko_Alfa For This Useful Post:
Old 09-24-2010, 16:04   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
I think this error may be a result of errors during communication, it may be a result of phone hardware or f.e. due to quite long cable wires.
Old 04-16-2011, 09:37   #4 (permalink)
mane_15's Avatar
Member: 1403558
Thanks Meter: 35
Data cable Aldrin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:06
cellular data suite kabel vingis Main Sales Section 0 11-25-1999 19:18
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 Nk_Cable Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-10-1999 10:08
Cellular Data Suite Cables avaliable !!! vingis Main Sales Section 0 11-02-1999 17:35
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 nk.cable Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-14-1999 15:33
Page generated in 0.17284 seconds with 9 queries
