06-26-2011, 05:25 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | Vodafone 543 unlock done 3 sets module v3.96 Device: Alcatel-543X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7003:A004 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.E9C9CF9C .[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_9096F062].rpl ==================== New firmware found (v.3.96, database date: 21.06.2011): JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: E9C9CF9C rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 62F09690 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 268 provider: 543X-2AVDGB1 customization: CN26FC03 customization: XN26FC03 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... version is not found in database: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 00006F50->00006C50 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC03 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN use default security area (sec info, hash) pattern ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC03 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN use default security area (sec info, hash) pattern ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003879899 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_E9C9CF9C_9096F062_201106 25-195453.B0X.bin Finished, time used: 3 min 28 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
06-26-2011, 05:38 | #2 (permalink) |
Member: 653398 Status: Offline Thanks Meter: 669 | here is full flash new firmware not in support Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
