07-01-2011, 05:25 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | vodafone 547 after reset calibration dont work |
07-01-2011, 10:24 | #2 (permalink) | |
Are you sure that phone touchscreen panel works well ? If touchscreen panel is damaged you can try to make "bypass calibration". | |
07-02-2011, 00:09 | #4 (permalink) |
Member: 160928 Status: Offline Thanks Meter: 338 | yes i m sure phone was working fine only problem was when u go to open message it can not open after i formatted this problem come touch screen is good because i mention on my first post when it ask me to touch anywhere to calibration that time only work after dont work,and there is no option bypass calibration ,i also flash the phone i got the same phone i read full flash then i flash but stil no luck stil ask for calibrations. |
07-02-2011, 00:25 | #5 (permalink) |
Member: 160928 Status: Offline Thanks Meter: 338 | what log u want to me to send? i m sending detail log here plz check it Code: COM3 [VCP0] selected module v3.96 Device: Vodafone-547 Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (460800)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/01C00000 firmware size: 32Mb ffs size: 28Mb detect sec ro... detect custom parameters... detect project-id... project-id: VF_UK_EN_P107A4V1.2.0B06 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ZTENJ35_09A_BOOTLOADER_V005_MT6235B_VF_IS_EN_P107A4V1_3_2B01.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTENJ35_09A_PCB01_GPRS_MT6235B_S01.VF_UK_EN_P107A4V1_2_0B06.BIN project-id: VF_UK_EN_P107A4V1.2.0B06, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/01C00000 rom info structure: [standard] type (07) TCL-ID is absent ===> done Disconnect... done Finished, time used: 33 sec Remove/Install battery now ! salim |
07-10-2011, 23:19 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | If you are sure that touchscreen was working before - make "format ffs" and after that just make a calibration by ordinary way after phone power-on. In other case you have a good reason to check touchscreen panel, because if you make calibration via software you will get disabled touchscreen. Please, remember, that it's not possible to repair hardware touchscreen faults with software methods. |
07-10-2011, 23:22 | #12 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
07-10-2011, 23:29 | #13 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Ok, no problem I will add option DISABLE !!!! touchscreen in software, but why you need this option for phone that have only touchscreen ? Let me explain again: "calibration" option in software it's an option to bypass damaged touchscreen. To be honest I am not sure that you have tried to install another touchscreen panel to this phone, but if you have tried to do so - read my previous post. Also, if you really have another phone and you was able to swap touchscreen panels - did you tried to install panel from damaged to good one phone ? Please, do not post an answer so fast, you need some time to make that test. |
07-10-2011, 23:36 | #15 (permalink) | |
last time i used old version this time i m using 3.96 i can not remember what version i used last time. | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
wintesla doesnt work | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 14:51 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
