07-13-2010, 18:21 | #1 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,770 | Vodafone 547 INVALID Imei ? i received one dead vf547, flashed it with vf547 flash drom support, and after powering on ... INVALID Imei is written in top right corner ... phone works, but imei is some strange ... any idea how to fix this ? p.s. i tried with N281 flashes, it power on but says some error message operations log attached .... b.r. Alexandar |
07-14-2010, 13:08 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | Hello, Did you tried to repair imei with "Write" button from software "Service" page ? It may be that you need to use test-pint pinout (under battery) for this operation. |
07-14-2010, 20:32 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,770 | yes, i tried ... and result is : ==== [7/13/2010 6:36:15 PM] ==== COM18 [VCP0] selected module v3.49 Device: Vodafone-547 Checking data, wait... Action: repair security area Flash phone with firmware from support area ! Finished, time used: 0 sec Remove/Install battery now ! that button does nothing ..... just says to flash firmware etc. and i did it ... i also tried to select N281 as model ... the same result. bug in software ? b.r. Alex |
07-14-2010, 21:50 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | Hello, What MModule version you have used ? please, run MModule, select Vodafone-547 (do not select any other models before) and try to use "Write" button again. What is the results ? |
07-14-2010, 22:27 | #5 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,770 | Quote:
module v3.49 Device: Vodafone-547 Checking data, wait... Action: repair security area Flash phone with firmware from support area ! Finished, time used: 0 sec Remove/Install battery now ! always the same i think some kind of bug in SW ... ? b.r. Alex | |
The Following User Says Thank You to Brka For This Useful Post: |
07-14-2010, 22:56 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | I think you have tried to make something wrong. You DO NOT need to use "Repair security area" from software "Repair" page ! You have to use "Write" button in software "Service" page. If you can not see "Write" button - follow the next instruction: How to restore imei button: 1. Run Infinity-Box DongleManager: x:\Program Files\InfinityBox\DongleManager\DongleManager.exe 2. Press "Read dongle serial number (S/N)" button 3. Set "UK-Edition" option OFF (disabled) ! |
07-15-2010, 12:33 | #7 (permalink) | |
thanx for instructions b.r. Alex | |
07-15-2010, 14:40 | #8 (permalink) | |
all is working now. here's the log : Code: Loading data, wait... [Infinity Box] MModule v3.49 smart-card: connected S/N: 52E6:0116 Wait... Device: Vodafone-547 Action: "repair imei" Model: Vodafone-547 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 355473026000000 imei write method: mode-1 new imei-1: 359621031646631 verification Ok Finished, time used: 10 sec Remove/Install battery now ! Action: read/check information Model: Vodafone-547 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: ZTENJ35_09A_HW Software version: VF_UK_EN_P107A4V1.2. Software date: 2000.00.00 Barcode: MT012345678901234567 imei-1: 359621031646631 Finished, time used: 2 sec Remove/Install battery now ! you always prove you're #1 box supporters/makers cheers, ALex. | |
07-16-2010, 16:35 | #10 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | Quote:
ICQ: 347191919 e-mail: [email protected] | |
09-30-2011, 20:45 | #11 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Madrid, Spain
Member: 591052 Status: Offline Sonork: 100.1592747 Thanks Meter: 95 | Quote:
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
