05-22-2017, 15:53 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Bucharest-Romania Age: 51
Member: 14200 Status: Offline Sonork: Sonork id Thanks Meter: 117 | Vodafone 575 firmware help! I have Vodafone 575 its an Alcatel phone and i want to try to write firmware because phone is dead and i thing is soft brick; problem is: phone is MT6255 NAND and i can't flash via usb with CM2. i want to try with RX, TX and GND with MM module but i not find pinout. Can any one help me with pinout for this phone? Here is some info read with CM2 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 40 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6255 BB_CPU_HW : CA03 BB_CPU_SW : 0002 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6255_S0000 BROM Protocol Version : 05 Setting... Setting done , result code 0x0000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 2C00 B100 8000 5500 DEV[1] : 0400 0000 0000 0000 Select EMI : 0000000000000000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x85 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x005E , [MICRON] MT29F1G16ABB FLASH_DIE0 : 002C 00B1 0080 0055 FLASH_DIE1 : 0004 0000 0000 0000 FLASH_LEN : 0x08000000 INT_RAM : 0x00007000 EXT_RAM : 0x04000000 Done! Elapsed: 00:03:14 Reconnect Power/Cable! |
